EVGA GeForce GTX 1080 FTW GAMING ACX 3.0
The EVGA GeForce GTX 1080 featuring EVGA ACX 3.0 cooling has arrived. This new graphics card features NVIDIA's new "Pascal" graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
Performance
The GeForce GTX 1080 is a quantum leap in performance and power efficiency. It's built using ultra-fast FinFET and high-bandwidth GDDR5X technologies, and supports DirectX 12 features for the fastest, smoothest, most power-efficient gaming experiences. -
Next-gen gaming technologies
GeForce GTX 1080 uses the power of Pascal to meet the demands of the latest displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture - even in VR. -
VR ready
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment. -
Groundbreaking design
The GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks.
- EVGA GeForce GTX 1080 - FTW Edition - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- CUDA Cores
- 2560
- Effective Memory Clock
- 10 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- DVI-D , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 26.67 cm x 15.088 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- CUDA Cores
- 2560
- VR Ready
- Max Resolution
- 7680 x 4320 at 240 Hz
- 4
- API Supported
- LED indicator, Nvidia SLI ready, eVGA Active Cooling Xtreme (ACX), NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 10 GHz
- Bus Width
- 256-bit
- Bandwidth
- 320 GBps
- OS Required
- Microsoft Windows 7 / 8 / 10, Microsoft Windows 7 / 8 / 10 (64 bits)
- Required Power Supply
- 500 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- 26.67 cm
- 15.088 cm
- Limited warranty - 3 years
