The EVGA GeForce GTX 1070 featuring EVGA ACX 3.0 cooling is here. This new graphics card features NVIDIA's "Pascal" graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
These cards also feature EVGA ACX 3.0 cooling technology. EVGA ACX 3.0 once again brings exciting features to the award winning EVGA ACX cooling technology. SHP 3.0 gives increased heatpipes and copper contact area for cooler operation, and optimized fan curve for even quieter gaming. Of course, ACX 3.0 coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU. Select EVGA ACX 3.0 models will even feature a 10CM fan and RGB LED, allowing complete control over the color from EVGA Precision XOC.
- EVGA GeForce GTX 1070 SC GAMING ACX 3.0 - graphics card - GF GTX 1070 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1070
- Memory
- 8 GB GDDR5
- Core Clock
- 1594 MHz
- Boost Clock
- 1784 MHz
- CUDA Cores
- 1920
- Effective Memory Clock
- 8008 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 26.67 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1594 MHz
- Boost Clock
- 1784 MHz
- CUDA Cores
- 1920
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Dual Slot Fan Cooler, Nvidia SLI ready, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, 4+1 Phase Power Design, GameWorks, eVGA Active Cooling Xtreme (ACX) 3.0
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8008 MHz
- Bus Width
- 256-bit
- Bandwidth
- 256.3 GBps
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- 180 Watt
- 26.67 cm
- 11.115 cm
- Limited warranty - 3 years
