EVGA GQ Series 650Watt 80 Plus Gold Modular ATX Power Supply
Quicklinx: BRFMWS00 Mfr#: 210-GQ-0650-V3
90% efficiency or higher under typical loads and the highest quality Japanese brand capacitors ensure long-term reliability.
Semi-modular design allows you to only use the cables you need, helping to improve case airflow, eliminate unnecessary wires, and best of all. reduce cable clutter.
The EVGA ECO mode feature ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
  • Unrivaled performance
  • Modular design
  • Whisper silent
EVGA 650 GQ - power supply - 650 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V / EPS12V
80 PLUS Certification
80 PLUS Gold
3.18 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
+3.3V - 24 A , +5V - 24 A , +12V - 54 A , +5VSB - 3 A , -12V - 0.5 A
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
135 mm fan
15 cm x 16.5 cm x 8.5 cm
5-year warranty
ATX12V / EPS12V
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
Efficiency
90% (115VAC) / 92% (220-240VAC)
80 PLUS Gold
Power cable - external - 1.53 m
MTBF
100,000 hour(s)
Cooling System
135 mm fan
Overheat protection, solid capacitors, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, active CLAMP circuitry, Eco-Mode, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan, semi-modular
TUV, CB, FCC, RoHS, WEEE, cTUVus, ErP 2013, RCM
Limited warranty - parts and labour - 5 years
50 °C
15 cm
16.5 cm
8.5 cm
3.18 kg
