The EVGA GeForce GTX 950 features a true gaming GPU, designed for every PC gamer. It's built to deliver amazing performance. More powerful, this card delivers a truly interactive, cinematic experience in the games with advanced effects.
Dynamic Super Resolution technology
This innovative feature can deliver 4K fidelity to 1080p displays for exceptional detail and image quality. -
GameWorks technology
GameWorks pushes the limits of gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games. -
GPU Boost 2.0
Dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions. This allows gamers to push performance to another levels. -
Surround technology
With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. Add in a fourth accessory display to get access to your email, web, or other applications while you game. -
CUDA technology with OpenCL support
Unlock the power of the GPU's processor cores to accelerate demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements. -
PCI Express 3.0
This card is designed for the PCI Express 3.0 bus architecture, offering the high data transfer speeds for the bandwidth-hungry games and 3D applications. It also maintains backwards compatibility with existing PCI Express motherboards for the broad support.
- EVGA GeForce GTX 950 SC GAMING - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1076 MHz
- Boost Clock
- 1253 MHz
- CUDA Cores
- 768
- Effective Memory Clock
- 6610 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- DVI-I (dual link) , HDMI , DisplayPort , DVI-D (dual link)
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- 17.272 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1076 MHz
- Boost Clock
- 1253 MHz
- CUDA Cores
- 768
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6610 MHz
- Bus Width
- 128-bit
- Bandwidth
- 105.76 GBps
- OS Required
- Microsoft Windows Vista / 7 / 8 / 10 (32/64 bits)
- Required Power Supply
- 350 W
- 75 Watt
- 17.272 cm
- 11.115 cm
- Limited warranty - 3 years
