Product
Brand
EVGA GeForce GTX 950 SC Gaming Low Power 2GB GDDR5 PCIe3.0
Quicklinx: C3FTWS00 Mfr#: 02G-P4-0958-KR
The EVGA GeForce GTX 950 features a true gaming GPU, designed for every PC gamer. It's built to deliver amazing performance. More powerful, this card delivers a truly interactive, cinematic experience in the games with advanced effects.
EVGA GeForce GTX 950 SC GAMING - graphics card - GF GTX 950 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 950
2 GB GDDR5
Core Clock
1076 MHz
Boost Clock
1253 MHz
CUDA Cores
768
Effective Memory Clock
6610 MHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , HDMI , DisplayPort , DVI-D (dual link)
API Supported
OpenCL, OpenGL 4.4, DirectX 12
17.272 cm x 11.115 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1076 MHz
Boost Clock
1253 MHz
CUDA Cores
768
Max Resolution
4096 x 2160
4
API Supported
Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6610 MHz
Bus Width
128-bit
Bandwidth
105.76 GBps
Microsoft Windows Vista / 7 / 8 / 10 (32/64 bits)
Required Power Supply
350 W
75 Watt
17.272 cm
11.115 cm
Limited warranty - 3 years
