GEFORCE GTX 1060
10: Gaming Perfected
The GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal™—the most advanced GPU architecture ever created—the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. #GameReady.
NVIDIA PASCAL
THE WORLD'S MOST ADVANCED GPU ARCHITECTURE
GeForce GTX 10-series graphics cards are powered by Pascal to deliver up to 3x the performance of previous-generation graphics cards, plus innovative new gaming technologies and breakthrough VR experiences.
NVIDIA GameStream technology
Stream extreme GeForce GTX PC gaming experiences to portable device with super-smooth, low-latency performance. -
VR Ready
Discover next-generation VR performance, low latency, and plug-and-play compatibility with leading headsets-driven by NVIDIA VR technologies. -
NVIDIA GPU Boost 3.0
It dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions. -
NVIDIA G-Sync ready
NVIDIA G-Sync monitors feature revolutionary NVIDIA technology that eliminates screen tearing while also reducing input lag. The result is a smooth, fast, and responsive gaming experience.
- EVGA GeForce GTX 1060 SC Gaming - graphics card - GF GTX 1060 - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 6 GB GDDR5
- Core Clock
- 1607 MHz
- Boost Clock
- 1835 MHz
- CUDA Cores
- 1280
- Effective Memory Clock
- 8008 MHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Resolution Details
- DisplayPort: 7680 x 4320 at 60 Hz
- Max Monitors Supported
- 4
- DVI-D , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 17.272 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1607 MHz
- Boost Clock
- 1835 MHz
- CUDA Cores
- 1280
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8008 MHz
- Bus Width
- 192-bit
- Bandwidth
- 192 GBps
- OS Required
- Microsoft Windows Vista / 7 / 8 / 10 (32/64 bits)
- Required Power Supply
- 400 W
- Additional Requirements
- 6 pin PCI Express power connector
- 120 Watt
- 17.272 cm
- 11.115 cm
- Limited warranty - 3 years
