EVGA GeForce GTX 1060 SC GAMING 6GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C87YWS00 Mfr#: 06G-P4-6163-KR
GEFORCE GTX 1060
10: Gaming Perfected
The GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal™—the most advanced GPU architecture ever created—the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. #GameReady.
NVIDIA PASCAL
THE WORLD'S MOST ADVANCED GPU ARCHITECTURE
GeForce GTX 10-series graphics cards are powered by Pascal to deliver up to 3x the performance of previous-generation graphics cards, plus innovative new gaming technologies and breakthrough VR experiences.
  • NVIDIA GameStream technology
    Stream extreme GeForce GTX PC gaming experiences to portable device with super-smooth, low-latency performance.
  • VR Ready
    Discover next-generation VR performance, low latency, and plug-and-play compatibility with leading headsets-driven by NVIDIA VR technologies.
  • NVIDIA GPU Boost 3.0
    It dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions.
  • NVIDIA G-Sync ready
    NVIDIA G-Sync monitors feature revolutionary NVIDIA technology that eliminates screen tearing while also reducing input lag. The result is a smooth, fast, and responsive gaming experience.
EVGA GeForce GTX 1060 SC Gaming - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1607 MHz
Boost Clock
1835 MHz
CUDA Cores
1280
Effective Memory Clock
8008 MHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz
Max Monitors Supported
4
DVI-D , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
17.272 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1607 MHz
Boost Clock
1835 MHz
CUDA Cores
1280
VR Ready
Max Resolution
4
API Supported
NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8008 MHz
Bus Width
192-bit
Bandwidth
192 GBps
Microsoft Windows Vista / 7 / 8 / 10 (32/64 bits)
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
120 Watt
17.272 cm
11.115 cm
Limited warranty - 3 years
