EVGA GeForce GTX 1060 3GB GDDR5 PCIe 3.0 x16 DVI HDMI DisplayPort Graphics Card
Quicklinx: CPKQWS00 Mfr#: 03G-P4-6162-KR
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GTX 1060, NVIDIA GeForce GTX 1060, NVIDIA GeForce GTX 1060
Interface: PCI Express 3.0 x16
Memory Size: 3GB
£251.93 ex VAT
£302.31 inc VAT
The EVGA GeForce GTX 1060 graphics card is loaded with innovative gaming technologies, making it the perfect choice for the high-definition games. Powered by advanced GPU architecture the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond.
  • NVIDIA GameStream technology
    Stream extreme GeForce GTX PC gaming experiences to portable device with super-smooth, low-latency performance.
  • VR Ready
    Discover next-generation VR performance, low latency, and plug-and-play compatibility with leading headsets-driven by NVIDIA VR technologies.
  • NVIDIA GPU Boost 3.0
    It dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions.
  • NVIDIA G-Sync ready
    NVIDIA G-Sync monitors feature revolutionary NVIDIA technology that eliminates screen tearing while also reducing input lag. The result is a smooth, fast, and responsive gaming experience.
EVGA GeForce GTX 1060 SC Gaming - graphics card - GF GTX 1060 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
3 GB GDDR5
Core Clock
1607 MHz
Boost Clock
1835 MHz
CUDA Cores
1152
Effective Memory Clock
8008 MHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
17.272 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1607 MHz
Boost Clock
1835 MHz
CUDA Cores
1152
VR Ready
Max Resolution
4
API Supported
NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
8008 MHz
Bus Width
192-bit
Bandwidth
192 GBps
Microsoft Windows 7 / 8 / 10 (32/64 bits)
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
120 Watt
17.272 cm
11.115 cm
Limited warranty - 3 years
Memory Size: 3GB
Brand: EVGA
Price Range Ex VAT: 150 - 300
