Accelerate your entire PC experience with a new EVGA GeForce GT 740 graphics card. Enjoy all your videos and pictures at HD resolutions, with 10X faster video editing, 13X faster photo editing, and 9X faster web browsing compared to integrated graphics. Plus, experience 4X faster gaming performance that makes all your gameplay richer and smoother. You can even tap into GeForce Experience to automatically get the latest drivers and optimize game settings with a single click. The EVGA GeForce GT 740 is everything you love, a whole lot faster.
Performance
- NVIDIA GT 740
- 384 CUDA Cores
- 1059 MHz GPU
- 4096 MB, 128 bit DDR3
- 1334 MHz (effective)
- 21.35 GB/s Memory Bandwidth
- PCI-E 3.0 16x
- DVI-I, DVI-D, Mini-HDMI
Resolution & Refresh
- 240Hz Max Refresh Rate
- Max Analog : 2048x1536
- Max Digital : 4096x2160
Operating System Support
- Windows 8 32/64bit
- Windows 7 32/64bit
- Windows Vista 32/64bit
- Windows XP 32/64bit
Requirements
- Minimum of a 400 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 20 Amps.) Total Power Draw : 64 Watts
NVIDIA PhysX technology
Full support for NVIDIA PhysX technology, enabling a class of physical gaming interaction for a more dynamic and realistic experience with GeForce. -
NVIDIA SMX Engine
Next generation streaming multiprocessor is built from the ground up for incredible performance and power efficiency. -
NVIDIA Adaptive Vertical Sync
It dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. -
NVIDIA Surround
With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. NVIDIA Surround also supports triple screen gaming with non-3D Vision monitors. Add in a fourth accessory display to get access to your email, web, or other applications while you game. -
NVIDIA 3D Vision Ready
Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D. -
NVIDIA CUDA technology
It unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs. -
PCI Express 3.0 support
Designed for the new PCI Express 3.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support. -
NVIDIA FXAA technology
Shader-based anti-aliasing technology available from the NVIDIA control panel that enables ultra-fast anti-aliasing in hundreds of PC games. -
NVIDIA TXAA technology
Support for temporal anti-aliasing technique that delivers the ultimate combination of image quality and performance. -
NVIDIA PureVideo HD technology
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
- EVGA GeForce GTX 740 SuperClocked - graphics card - GF GT 740 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GT 740
- Memory
- 4 GB GDDR3
- Core Clock
- 1059 MHz
- CUDA Cores
- 384
- Effective Memory Clock
- 1.334 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-I , DVI-D , HDMI
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- 15.24 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1059 MHz
- CUDA Cores
- 384
- Max Resolution
- 4096 x 2160
- API Supported
- Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, x.v.Color technology, Deep Color technology, Blu-Ray 3D Support, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine
- Size
- 4 GB
- Technology
- GDDR3 SDRAM
- Effective Clock Speed
- 1.334 GHz
- Bus Width
- 128-bit
- Bandwidth
- 21.35 GBps
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Required Power Supply
- 400 W
- 64 Watt
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X, GeForce Experience
- 15.24 cm
- 11.115 cm
- Limited warranty - 3 years
