Product
EVGA 700W 700B 80+ Bronze Power Supply
Quicklinx: BZXHWS00 Mfr#: 100-B1-0700-K3
£54.06 ex VAT
£64.87 inc VAT
The EVGA 700B Power Supply is the best value for your next build. With 80 Plus Bronze standard, over 85% efficiency under typical loads, the EVGA 700B is a great choice. Combining 700W of continuous power make and a single + 12V supporting 56A, make this the perfect power supply for a high performance SLI system. Stay protected with a series of multiple safety protections all bundled into one!
EVGA 700B Bronze - power supply - 700 Watt
Power supply - internal
Specification Compliance
ATX12V / EPS12V
80 PLUS Certification
80 PLUS Bronze
2.3 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.5 cm
3 years warranty
ATX12V / EPS12V
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
+5V - 20 A , +3.3V - 24 A , +12V - 56 A , -12V - 0.3 A , +5VSB - 3 A
Efficiency
85%
80 PLUS Bronze
Power cable - external - 1.2 m
MTBF
100,000 hour(s)
Cooling System
120 mm fan
Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
UL, TUV, cUL, CB, FCC, RoHS, WEEE, ErP 2013
Limited warranty - parts and labour - 3 years
50 °C
15 cm
14 cm
8.5 cm
2.3 kg
EVGA 700W 700B 80+ Bronze Power Supply Bundle deal on EVGA 700W 700B 80+ Bronze Power Supply
£149.07
Brand: EVGA
Price Range Ex VAT: 50 - 100
