With price and performance in mind, the EVGA 600B is the best value power supply for your next build on a budget. With 80 plus bronze standard, over 80% efficiency under typical loads, the EVGA 600B is a great choice. Combining 600 W of continuous power and single +12 V high AMP rail design, gain maximum power and efficiency while staying protected with a series of multiple safety protections all bundled into one!
- EVGA 600B Bronze - power supply - 600 Watt
- Power supply - internal
- Specification Compliance
- ATX12V
- 80 PLUS Certification
- 80 PLUS Bronze
- 2 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- +5V - 20 A , +3.3V - 24 A , +12V - 49 A , -12V - 0.3 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- 15 cm x 14 cm x 8.5 cm
- 3-year warranty
- ATX12V
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- Efficiency
- 85%
- 80 PLUS Bronze
- Cables Included
- Power cable 1.2 m
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, Intelligent Fan Control Technology
- UL, TUV, FCC, RoHS, cULus
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 15 cm
- 14 cm
- 8.5 cm
- 2 kg
