When building on a budget, the EVGA 430W 80 PLUS is a great choice at a low cost. Supporting 34A on a single +12V rail provides more options without having to reduce your component requirements. Save space with the 430W's compact design, well-placed power switch and fully sleeved cables. The 430W offers the connections and protections needed for basic system builds. With a standard 3 year warranty and ultra quiet fan design the 430W will be a great asset for your next build on a budget.
CABLE LENGTH
- ATX CABLE 1x 550mm
- EPS CABLE 1x 600mm
- PCIE CABLE 1x 550mm
- SATA CABLE 2x 450mm, 570mm
- FOUR-PIN PERIPHERAL CABLE 1x 450mm, 570mm, 690mm (f)
- FLOPPY CABLE 1x 120mm
- AC POWER 1x 1200mm (m)
FEATURES
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
- 3 Year Warranty (More Info)
- Quiet and Intelligent Auto Fan for near-silent operation
- EVGA - power supply - 430 Watt
- Power supply - internal
- 1.8 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 430 Watt
- Output Current
- +5V - 15 A , +3.3V - 24 A , +12V - 34 A , -12V - 0.3 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- 15 cm x 14 cm x 8.5 cm
- 3-year warranty
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 430 Watt
- Output Current
- Efficiency
- 80%
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
- UL, TUV, FCC, RoHS, WEEE, cULus
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 15 cm
- 14 cm
- 8.5 cm
- 1.8 kg
