EVGA 1200W SuperNOVA 1200 P2 80+ Platinum Fully Modular PSU
Quicklinx: 9KVLWS00 Mfr#: 220-P2-1200-X3
Introducing the EVGA SuperNOVA 1200 P2 power supply. This power supply raises the bar with 1200W of continuous power delivery and 92% efficiency. A fully modular design reduces case clutter and 100% Japanese Capacitors ensures that only the absolute best components are used. What does that mean? The best stability, reliability, overclockability and unparalleled control. The EVGA SuperNOVA 1200 P2 is the ultimate tool to eliminate all system bottlenecks and achieve unrivaled performance.
  • Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
  • Highest quality Japanese brand capacitors ensure long-term reliability
  • Fully Modular to reduce clutter and improve airflow
  • NVIDIA SLI Ready
  • Double Ball Bearing fan for exceptional reliability and quiet operation
  • Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
  • 80 PLUS Platinum high efficiency power supply certified - 50% load (92% Efficiency)
Cables
  • ATX Cable 1x 600mm (m)
  • EPS Cable 2x 750mm (m)
  • PCIE Cable 2x 750mm, 900mm (m) 4x 750mm (m)
  • SATA Cable 4x 550mm, 650mm, 750mm (m)
  • Four-Pin Peripheral Cable 1x 550mm, 650mm 750mm (m) 1x 550mm,650mm (m) (f)
  • Floppy Adapter 1x 100mm
  • AC Power 1x 1500mm (m)
  • Modular Cable Type Full
Connector
  • 24 Pin ATX 1x
  • EPS (CPU) 2x 8pin (4+4)
  • PCIE 6x 8pin (6+2), 2x 6pin
  • SATA 12x
  • Four-Pin Peripheral 5x
  • Floppy 1x
EVGA SuperNOVA 1200 P2 - power supply - 1200 Watt
Power supply - internal
Specification Compliance
ATX / EPS
80 PLUS Certification
80 PLUS Platinum
3.6 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1200 Watt
Output Current
+5V - 20 A , +3.3V - 20 A , +12V - 99.5 A , -12V - 0.5 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin main output , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 12 x 15 pin Serial ATA power , 5 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
140 mm fan
15 cm x 20 cm x 8.5 cm
10-year warranty with product registration
ATX / EPS
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1200 Watt
Output Current
Efficiency
92%
80 PLUS Platinum
MTBF
100,000 hour(s)
Cooling System
140 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, short-circuit protection, single 12V rail, Eco-Mode, fully modular
TUV, C-Tick, BSMI, CB, CCC, FCC, RoHS, cTUVus
Limited warranty - parts and labour - 10 years
50 °C
15 cm
20 cm
8.5 cm
3.6 kg
Resources
The following resources are available for the EVGA 1200W SuperNOVA 1200 P2 80+ Platinum Fully Modular PSU
