Your basket is empty
Euroscreen XL Diplomat 390 x 292.5cm (4:3
Quicklinx: 7269WS00 Mfr#: MD4030-V
Euroscreen XL Diplomat Large Electric Projection ScreenEuroscreen XL Diplomat electric projection screen. Viewing Area 390cm x 292.5cm (4:3) 192 diagonal.Matt White front projection surface with black borders.Overall Surface dimension 400cm wide x 320cm high. White aluminium extruded case with channel fix brackets to suit ceiling or wall Complete with 3m cable with unterminated 4 core cable. For integration with a wall switch please use SOMFY-SWITCH 1 gang UK sized in white (
