Connect is a basic compact screen which is very easy to install. The case is made of steel. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case.
- Euroscreen Connect Wide Format - projection screen
- Product Type
- Projection screen
- Placing / Mounting
- Ceiling mountable, wall mountable
- Projection Image Size
- 170 cm x 95 cm
- Aspect Ratio
- 16:9
- Screen Surface
- Matte White
- 189 cm 165 cm
- 7.3 kg
- Product Type
- Projection screen
- Image Width
- 170 cm
- Image Height
- 95 cm
- Screen Surface
- Matte White
- Aspect Ratio
- 16:9
- Viewing Angle
- 180°
- 189 cm 165 cm
- 7.3 kg
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
69XK 040484 Condition: This item is new and unused. The packaging is damaged. |
£26.74 |
Ref:
69XK 040485 Condition: This item is new and unused. The packaging is damaged. |
£26.74 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
