Product
Ergotron WorkFit-A Single HD with Worksurface+
Quicklinx: 93KMWS00 Mfr#: 24-314-026
Ideal for corner workstations, the WorkFit-A clamps to the rear or side of most surfaces and enables an effortless sit-and-stand work style. Fold the keyboard up and swing the arm out of the way when you need your desk surface.
Change from a sitting to a standing position whenever you want. This height-adjustable desk workstation moves your keyboard and display in one simple motion, making computing comfortable for prolonged periods.
Ergotron WorkFit-A Single HD with Worksurface+ - stand
Stand
Mounting Components
Tray, articulating arm, desk clamp mount, pivot
Adjustments
Pan, tilt
Recommended Use
LCD display / keyboard / mouse
Recommended Display Size
Up to 30"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Black, polished aluminium
5 years warranty
AV Furniture
Stand
Mounting Components
Recommended Use
Cable Management
Cable Management System (CMS)
Up to 30"
Adjustments
Pan, tilt
Max Load Weight
11.3 kg
Adjustable height, rotating, Constant Force Technology
Limited warranty - 5 years
