Ergotron Side by Side Mount
Quicklinx: 6MDLWS00 Mfr#: 45-245-026
Accessory Type: Mount
35 in stock
£216.69 ex VAT
£260.02 inc VAT
Durable polished aluminum construction! Create a fully adjustable side-by-side configuration that lifts both LCD screens up to where they're easier to see while reclaiming valuable worksurface.
Reposition your LCDs with just a touch. Up. Down. Forward. Back. The LX provides unparalleled range of motion. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs.
Ergotron LX Dual Side-by-Side Arm - mounting kit
Mounting kit - desktop
Mounting Components
Desk clamp mount, grommet mount, pole, 2 articulating arms, 2 extension brackets, t-bracket
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
6.3 kg
Recommended Use
2 LCD displays
Recommended Display Size
Up to 27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
18.1 kg
Material
Polished aluminium
10 years warranty
6.3 kg
Material
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
2 LCD displays
Placing / Mounting
Desktop
Cable Management
Integrated cable management
Up to 27"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Max Load Weight
18.1 kg
Rotating, portrait to landscape movement
Dimensions & Weight Details
49 cm x 25 cm x 16 cm / 7.9 kg
Limited warranty - 10 years
Brand: Ergotron
Price Range Ex VAT: 150 - 300
