Durable polished aluminum construction! Create a fully adjustable side-by-side configuration that lifts both LCD screens up to where they're easier to see while reclaiming valuable worksurface.
Reposition your LCDs with just a touch. Up. Down. Forward. Back. The LX provides unparalleled range of motion. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs.
- Ergotron LX Dual Side-by-Side Arm mounting kit - Patented Constant Force Technology - for 2 LCD displays - polished aluminium
- Product Type
- Mounting kit (Patented Constant Force Technology)
- Mounting Components
- Desk clamp mount, grommet mount, pole, 2 articulating arms, 2 extension brackets, t-bracket, base
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Height, pan, tilt, rotation, lift
- 6.3 kg
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- Up to 27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 18.1 kg
- Material
- Aluminium, steel
- Polished aluminium
- 10 years warranty
- 6.3 kg
- Material
- Aluminium, steel
AV Furniture
- Mounting kit
- Design
- Recommended Use
- 2 LCD displays
- Cable Management
- Integrated cable management
- Up to 27"
- Tilt
- 75°
- Pan
- 360°
- Lift
- 33 cm
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 18.1 kg
- Min Load Weight
- 6.4 kg
- Rotating, portrait to landscape movement
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 49 cm x 45 cm x 16 cm / 7.9 kg
- Limited warranty - 10 years
