Your basket is empty
Ergotron PS Laptop Charging Cart 20 units
Quicklinx: BYWHWS00 Mfr#: 24-294-085
This cart's universal interface charges up to 20 devices. PowerShuttle technology optimizes total charge time while safely preventing electrical circuit overload by efficiently grouping the number of devices that are charged at one time. It can work in any environment, including education, healthcare and enterprise applications.
Ergotron PowerShuttle Laptop Charging Cart - cart
Cart
71.1 cm x 62 cm x 101.6 cm
66.2 kg
Hong Kong, Singapore, United Kingdom
Recommended Use
20 notebooks
Material
Steel, ABS plastic
5 years warranty
71.1 cm
62 cm
101.6 cm
66.2 kg
Material
Steel, ABS plastic
AV Furniture
Cart
Recommended Use
20 notebooks
Cable Management
Integrated cable management
Wheel Diameter
10.2 cm
Lockable, built-in handle, power outlet, battery status indicator, ventilation system, automatic temperature control, PowerShuttle
Limited warranty - 5 years , Limited warranty - power system - 2 years , Limited warranty - 1 year
