Ergotron Neo-Flex Tilting Wall Mount, UHD - Mounting kit
Quicklinx: F807WS00 Mfr#: 60-612
Neo-Flex Tilting Wall Mount, UHD fits most 37"–80" flat panels up to 175 lbs (79 kg) and is the ideal mount for those looking for an easy-to-use large tilt mount.
Ergotron Neo-Flex mounting kit - ultra heavy-duty - for flat panel - black
Mounting kit (ultra heavy-duty)
Mounting Components
Wall plate, locking bar, 2 tilt rails
82.6 cm
Tilt
15°
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
37"-80"
VESA Mounting Interface
From 100 mm, up to 600 mm
Max Load Weight
79.4 kg
Package Content
Mounting hardware
3-year warranty
82.6 cm
Package Content
Mounting hardware
AV Furniture
Mounting kit
Mounting Components
Design
Ultra heavy-duty
Recommended Use
Flat panel
37"-80"
Tilt
15°
Adjustments
Tilt
Max Load Weight
79.4 kg
Dimensions & Weight Details
Dimensions
Wall plate - width: 82.6 cm height: 37.5 cm , Mounting rail - width: 4.5 cm
37.2 cm x 86.1 cm x 8.1 cm / 9.3 kg
Limited warranty - 3 years
