Durable polished aluminum construction! Use this ingenious tool with your notebook and an external LCD or with two LCDs. Create a productive multi-display configuration that lifts screens up to where they're easier to see while reclaiming valuable worksurface.
- Ergotron LX Dual Stacking Arm - mounting kit
- Product Type
- Mounting kit - table mount
- Mounting Components
- Tray, desk clamp mount, grommet mount, pole, 2 articulating arms, 2 extension brackets
- Integrated Devices
- Flat panel lift
- Tilt
- Pan
- Recommended Use
- 2 LCD displays or LCD display and notebook
- Recommended Display Size
- Up to 24"
- Flat Panel Mount Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 18.1 kg
- Polished aluminium
- 5 years warranty
AV Furniture
- Mounting kit
- Recommended Use
- Placing / Mounting
- Table mount
- Flat panel lift
- Up to 24"
- Tilt
- Pan
- Max Load Weight
- 18.1 kg
- Adjustable height, rotating
- Limited warranty - 5 years
