Product
ErgoMounts LX Wall Mount LCD Arm
Quicklinx: 71YLWS00 Mfr#: 45-243-026
Type: Mounting kit
44 in stock
£94.61 ex VAT
£113.53 inc VAT
Durable polished aluminum construction! Tested to perform 10 times the expected life-cycle of other competitive brands at roughly half the price. Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. The LX provides unparalleled range of motion.
Ergotron LX Wall Mount LCD Arm - mounting kit
Mounting kit - wall-mountable
Mounting Components
Articulating arm, mounting base, extension brackets
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
Up to 27"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9.1 kg
Material
Aluminium
10 years warranty
Material
Aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Up to 27"
Adjustments
Tilt
Max Load Weight
9.1 kg
Horizontal or vertical screen orientation, adjustable height, rotating
Limited warranty - 10 years
Type: Mounting kit
Brand: ErgoMounts
Price Range Ex VAT: 50 - 100
