ErgoMounts LX Wall Mount LCD Arm
Quicklinx: 71YLWS00 Mfr#: 45-243-026
Type: Mounting kit
£137.42 ex VAT
£164.90 inc VAT
Durable polished aluminum construction! Tested to perform 10 times the expected life-cycle of other competitive brands at roughly half the price. Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. The LX provides unparalleled range of motion.
Ergotron LX mounting kit - for LCD display - polished aluminium
Mounting kit
Mounting Components
Wall mount, monitor arm
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Tilt, pan, lift, rotation
2.5 kg
Recommended Use
LCD display
Recommended Display Size
Up to 34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Aluminium
Polished aluminium
10 years warranty
2.5 kg
Material
Aluminium
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Up to 34"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Max Load Weight
11.3 kg
Min Load Weight
3.2 kg
Horizontal or vertical screen orientation, adjustable height, rotating
Dimensions & Weight Details
44.5 cm x 19.7 cm x 16.8 cm / 2.8 kg
Limited warranty - 10 years
71YL Ergotron Thin Client Mounting Kit In Stock £36.01
Type: Mounting kit
Brand: ErgoMounts
