Product
ErgoMounts LX DESK MOUNT LCD ARM
Quicklinx: 76G5WS00 Mfr#: 45-241-026
Accessory Type: Mount
More than 50 in stock
£101.94 ex VAT
£122.32 inc VAT
Durable polished aluminum construction! Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. The LX provides unparalleled range of motion.
Ergotron LX Desk Mount LCD Arm - mounting kit
Mounting kit
Mounting Components
Articulating arm, desk clamp mount, extension adapter, grommet-mount base, 7" post
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
3.6 kg
Recommended Use
LCD display
Recommended Display Size
Up to 34"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Polished aluminium
10 years warranty
3.6 kg
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Cable Management
Integrated cable management
Up to 34"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Max Load Weight
11.3 kg
Min Load Weight
3.2 kg
Horizontal or vertical screen orientation, adjustable height, rotating
Dimensions & Weight Details
45 cm x 27 cm x 17 cm / 4.4 kg
Limited warranty - 10 years
Brand: ErgoMounts
Price Range Ex VAT: 100 - 150
