ErgoMounts LX DESK MOUNT LCD ARM
Quicklinx: 76G5WS00 Mfr#: 45-241-026
Accessory Type: Mount
More than 50 In Stock
£116.30 ex VAT
£139.56 inc VAT
Durable polished aluminum construction! Sleek and streamlined, the LX frees up space and allows positioning of your display for greater productivity. Reposition your LCD with just a touch. The LX provides unparalleled range of motion.
  • Comfortable fit
    Offers ergonomic monitor positioning using patented Constant Force Technology.
  • More motion
    Luxury arm easily adjusts monitors up to 34" in size.
  • Saves space
    Places screen in the best view to tackle each to-do.
  • Sleek build
    Streamlined look enhances your work area.
  • Easy storage
    Folds to fit under storage shelves or cabinets.
  • Quality design
    Built for years of use by passing a 10,000-cycle motion test.
Ergotron LX mounting kit - for LCD display - polished aluminium
Mounting kit
Mounting Components
Articulating arm, desk clamp mount, extension adapter, grommet-mount base, 7" post
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Pan, tilt, rotation, lift
3.6 kg
Recommended Use
LCD display
Recommended Display Size
Up to 34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Polished aluminium
10 years warranty
3.6 kg
Polished aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Cable Management
Integrated cable management
Up to 34"
Tilt
75°
Pan
360°
Lift
33 cm
Rotation
360°
Adjustments
Max Load Weight
11.3 kg
Min Load Weight
3.2 kg
Horizontal or vertical screen orientation, adjustable height, rotating
Dimensions & Weight Details
45 cm x 27 cm x 17 cm / 4.4 kg
Limited warranty - 10 years
76G5 ErgoMounts 50-193-200 Notebook Tray In Stock £39.28
76G5 Ergotron Thin Client Mounting Kit In Stock £35.86
Brand: ErgoMounts
