Save up to 30% ink with Epson's individual ink cartridges
With Epson's individual inks, you only replace the colour used, saving you up to 30% ink compared to competitors' tri-colour cartridges.
Reduce your printing costs with XL inks
Epson offers a choice of standard or extra large (XL) ink cartridges across its latest ink ranges. XL inks are ideal if you print high volumes and can reduce your printing costs by up to 25%
Epson inks are optimised for Epson printers
Epson inks and papers have been developed to work hand-in-hand with Epson printers to produce the best results time and time again.
With Epson's individual inks, you only replace the colour used, saving you up to 30% ink compared to competitors' tri-colour cartridges. -
Epson offers a choice of standard or extra large (XL) ink cartridges across its latest ink ranges. XL inks are ideal if you print high volumes and can reduce your printing costs by up to 25% -
- Epson 29XL - XL - cyan - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Cyan
- Capacity
- 6.4 ml
- Cartridge Yield
- XL
- Cartridge Features
- Epson Claria Home Ink
- Yield
- Up to 450 pages
- Compatible with
- Expression Home XP-235, XP-245, XP-247, XP-332, XP-335, XP-342, XP-345, XP-432, XP-435, XP-442, XP-445
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Cyan
- Included Qty
- 1-pack
- Capacity
- 6.4 ml
- Cartridge Yield
- XL
- Yield
- Up to 450 pages
- Compatible with
- Epson Expression Home XP-235, XP-245, XP-247, XP-332, XP-335, XP-342, XP-345, XP-432, XP-435, XP-442, XP-445
