Epson WorkForce WF-7710DWF - multifunction printer (colour)
Quicklinx: D6NWWS00 Mfr#: C11CG36411
£159.72 ex VAT
£191.66 inc VAT
Professional A3 printing
This A3 4-in-1 printer will meet the needs of even the most demanding home office and small office users. It offers double-sided (duplex) printing, scanning and faxing all up to A3, plus its automatic document feeder can process up to 35 double-sided A3 pages. Furthermore, its PrecisionCore printhead produces high-quality, laser-like prints.
Enhance your productivity
This efficient, reliable and fast model offers A3 double-sided printing and print speeds of 18ppm in black and 10ppm in colour . It's also simple to operate directly thanks to its intuitive user interface and 10.9cm touchscreen.
Minimise your outgoings
Dramatically reduce your costs; this printer offers up to 50 percent lower cost-per-page than competitors' laser models4. Giving great value for money, cartridges are available in standard, XL and XXL, with the highest yield delivering up to 2,200 pages5.
Flexible wireless solutions
Print from anywhere in the office with Wi-Fi connectivity or use Wi-Fi Direct to print from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible Android device on the printer . Epson's free mobile printing apps and solutions provide further versatility; Email Print allows you to send items to print from almost anywhere in the world . And with Scan-to-Cloud, you can enjoy the benefits of collaborative working .
  • A3 duplex 4-in-1
    Expand your potential with this A3 4-in-1 inkjet. It offers high-quality, low-cost-printing and flexible wireless solutions including NFC .
Epson WorkForce WF-7710DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
20000 pages
Max Printing Speed
Up to 32 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 4800 x 2400 dpi (mono) / up to 4800 x 2400 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
A3 Plus (329 x 483 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
125 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Scan to Cloud
AC 230 V
56.7 cm x 45.2 cm x 34 cm
18.7 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
Colour Support
Display Features
Touch screen
AirPrint Enabled
Scan to Cloud
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (black), 3 x 256 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2.8 pl
Printer Drivers / Emulations
EPSON ESC/P-R
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, colour faxing
Document & Media Handling
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, A3 Plus (329 x 483 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
250 sheets
Max Media Capacity
250 sheets
125 sheets
Input tray - 250 sheets , ADF - 35 sheets , Output tray - 125 sheets
Speed Details
Printing: up to 18 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: up to 8.7 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 6 ppm (A4) - colour duplex (ISO/IEC 24734) , Printing: up to 32 ppm - B/W , Printing: up to 20 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2003 R2, Windows 8, MS Windows Server 2012 x64 Edition, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Windows 10
Software Included
Drivers & Utilities
AC 230 V
19 Watt
Power Consumption Standby
8.5 Watt
Power Consumption Sleep
1.7 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - on-site
56.7 cm
45.2 cm
34 cm
18.7 kg
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A3 Plus (329 x 483 mm)
Brand: Epson
Price Range Ex VAT: 150 - 300
