Epson WorkForce WF-100W Portable Inkjet Colour Printer
Quicklinx: BP2ZWS00 Mfr#: C11CE05402BY
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Portable printing
The world's smallest and lightest wireless A4 inkjet printer , the WF-100W has a built-in battery that can be recharged anywhere via USB. It's small and compact, measuring just 309x154x61mm and weighing 1.6kg. Its wireless connectivity means the WF-100W cuts out all cables, allowing it to be used hassle-free both in clients' homes or in a vehicle.
Convenient
Compatible with Apple AirPrint and Google Cloud Print for wireless printing, the WF-100W also benefits from Epson Connect. As well as the Epson iPrint app for wireless printing from most tablets or smartphones, Epson Connect also includes Email Print, which means you can print from anywhere in the world .
High quality
The quality of this printer is reflected in the quality of the printouts. In fact, it is the only portable printer that uses pigment inks, for durable, smudge-free results.
Efficient
The WF-100W delivers an ISO print speed of 7ppm in black and 4ppm in colour4 and has an ink yield of up to 250 pages in black and 200 in colour5. The only portable printer with an LCD screen , it's always easy to set-up a Wi-Fi connection without the need for a PC, and to check ink supply levels.
  • Portable A4 printing
    Print anywhere with Epson's smallest and lightest wireless A4 inkjet printer that can be charged on the go via USB.
Epson WorkForce WF-100W - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
1.6 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 14 ppm - B/W , Up to 11 ppm - colour , Up to 7 ppm - B/W (ISO/IEC 24734) , Up to 4 ppm - color (ISO/IEC 24734)
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Media Type
Envelopes, plain paper
Print server
AC 120/230 V
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x
Enclosure Colour
30.9 cm x 15.4 cm x 6.1 cm
Printer Type
Enclosure Colour
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Minimum Ink Droplet Size
3 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
5760 x 1440 dpi
5760 x 1440 dpi
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
Media Weight
300 g/m²
Media Feeders
1 x automatic - 20 sheets - Legal (216 x 356 mm)
Print server
Remote Management Protocol
IPP
1 x USB 2.0 - 4 pin mini-USB Type B
2 x maintenance boxes
1 x mini-USB cable
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
11 Watt
Power Consumption Stand by
4 Watt
Power Consumption Sleep
1.3 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
45 dBA
30.9 cm
15.4 cm
6.1 cm
1.6 kg
BP2Z Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £12.56
BP2Z Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.49
BP2Z Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £11.83
