Ecological
The WF-M5690DWF uses up to 80 percent less power than competitive mono lasers thanks, in part, to its no heat technology. No Ozone gas is emitted and an improved quiet print mode and no fan noise during or after printing make it ideal for the work environment.
Low running costs
The WF-M5690DWF's high-capacity ink cartridges of up to 10,000 pages allow you to print for longer and lower your running costs. And there are fewer parts to replace than a laser.
Save time
This efficient business printer has print speeds of up to 34ppm, (20ppm ISO print speed ). Its maximum paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages4means you can print lots in confidence.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router. Email Print for Enterprise5 allows you to securely send documents directly to the multifunction printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
Fast, low-energy mono printing
This business inkjet multifunction printer benefits from up to 80% lower power consumption , increased productivity and lower intervention.
- Epson WorkForce Pro WF-M5690DWF - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (monochrome)
- Inkjet Technology
- Epson PrecisionCore
- Monthly Duty Cycle (max)
- 35000 pages
- Max Copying Speed
- Up to 19 ppm
- Max Copying Resolution
- Up to 600 x 1200 dpi
- Max Printing Speed
- Up to 11 ppm
- Max Printing Resolution
- Up to 1200 x 2400 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- Letter A (216 x 279 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 330 sheets
- Max Media Capacity
- 580 sheets
- Bypass Feeder Capacity
- 80 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to folder, scan to network, scan to SharePoint
- Power
- AC 230 V
- 46.1 cm x 42.2 cm x 34.2 cm
- 14.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - monochrome
- 35000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
Copying
- Max Copying Speed
- Up to 19 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page
Printing
- Inkjet Technology
- Nozzle Configuration
- 1600 nozzles
- Up to 11 ppm
- Minimum Ink Droplet Size
- 6.1 pl
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF 1.7, EPSON ESC/P-R
- Ink Type
- Epson DURABrite Ultra inks
- First Print Out Time B/W
- 7 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 550 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Automatic redialing, e-mail function, colour faxing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 330 sheets
- 580 sheets
- 80 sheets
- 150 sheets
- Input tray - 250 sheets , Bypass tray - 80 sheets , Output tray - 150 sheets , ADF - 35 sheets
- Speed Details
- Printing: up to 34 ppm - B/W , Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - B/W (ISO/IEC 24734) , Copying: up to 19 ipm - B/W (ISO/IEC 24735) , Scanning: up to 6.3 ipm (A4) - B/W , Scanning: up to 4.5 ipm (A4) - colour , Scanning: 5 sec (A4) - B/W , Scanning: 14 sec (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, Wi-Fi Direct
- Operating System Support
- MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V
- 22 Watt
- Power Consumption Standby
- 8.9 Watt
- Power Consumption Sleep
- 2.6 Watt
- Consumables Included
- 1 x ink cartridge (black)
- ENERGY STAR Certified
- 46.1 cm
- 42.2 cm
- 34.2 cm
- 14.1 kg
- Sound Emission
- 51 dBA (operating)
