Epson WorkForce Pro WF-M5690DWF Mono A4 Multifunction Printer
Quicklinx: B9MJWS00 Mfr#: C11CE37401BY
Ecological
The WF-M5690DWF uses up to 80 percent less power than competitive mono lasers thanks, in part, to its no heat technology. No Ozone gas is emitted and an improved quiet print mode and no fan noise during or after printing make it ideal for the work environment.
Low running costs
The WF-M5690DWF's high-capacity ink cartridges of up to 10,000 pages allow you to print for longer and lower your running costs. And there are fewer parts to replace than a laser.
Save time
This efficient business printer has print speeds of up to 34ppm, (20ppm ISO print speed ). Its maximum paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages4means you can print lots in confidence.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router. Email Print for Enterprise5 allows you to securely send documents directly to the multifunction printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
  • Fast, low-energy mono printing
    This business inkjet multifunction printer benefits from up to 80% lower power consumption , increased productivity and lower intervention.
Epson WorkForce Pro WF-M5690DWF - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (monochrome)
Inkjet Technology
Epson PrecisionCore
Monthly Duty Cycle (max)
35000 pages
Max Copying Speed
Up to 19 ppm
Max Copying Resolution
Up to 600 x 1200 dpi
Max Printing Speed
Up to 11 ppm
Max Printing Resolution
Up to 1200 x 2400 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
Letter A (216 x 279 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
330 sheets
Max Media Capacity
580 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to folder, scan to network, scan to SharePoint
AC 230 V
46.1 cm x 42.2 cm x 34.2 cm
14.1 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - monochrome
35000 pages
Display Features
Touch screen
AirPrint Enabled
Copying
Max Copying Speed
Up to 19 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Fit to page
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
1600 nozzles
Max Printing Speed
Up to 11 ppm
Minimum Ink Droplet Size
6.1 pl
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF 1.7, EPSON ESC/P-R
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
First Print Out Time B/W
7 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, e-mail function, colour faxing
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
330 sheets
Max Media Capacity
580 sheets
80 sheets
150 sheets
Input tray - 250 sheets , Bypass tray - 80 sheets , Output tray - 150 sheets , ADF - 35 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - B/W (ISO/IEC 24734) , Copying: up to 19 ipm - B/W (ISO/IEC 24735) , Scanning: up to 6.3 ipm (A4) - B/W , Scanning: up to 4.5 ipm (A4) - colour , Scanning: 5 sec (A4) - B/W , Scanning: 14 sec (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, Wi-Fi Direct
Operating System Support
MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities
AC 230 V
22 Watt
Power Consumption Standby
8.9 Watt
Power Consumption Sleep
2.6 Watt
Consumables Included
1 x ink cartridge (black)
ENERGY STAR Certified
46.1 cm
42.2 cm
34.2 cm
14.1 kg
Sound Emission
51 dBA (operating)
