This small workgroup multifunction device is perfect for the business environment, from small offices to large corporates who may have traditionally used lasers and want to cut costs, increase productivity and reduce downtime. This is while also cutting their business' environmental impact and improving their CSR reputation.
Fast, small workgroup MFD
Reduce your business printing costs and environmental impact, all while increasing productivity with less intervention and enhanced security.
- Epson WorkForce Pro WF-C5790DWF - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Monthly Duty Cycle (max)
- 45000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 22 ppm (colour)
- Max Copying Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Copying Resolution Class
- Max Printing Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 64 x 127 mm (min) - 216 x 60000 mm (max)
- Media Type
- Envelopes, plain paper, recycled paper, glossy photo paper
- Standard Media Capacity
- 330 sheets
- Max Media Capacity
- 830 sheets
- Bypass Feeder Capacity
- 80 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP
- Power
- AC 120/230 V (50/60Hz)
- 42.5 cm x 53.5 cm x 35.7 cm
- 18.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 45000 pages
- 250 - 2500 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Inkjet Technology
- Nozzle Configuration
- 800 nozzles (black), 3 x 800 nozzles (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.8 pl
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7, EPSON ESC/P-R
- First Print Out Time B/W
- 5 sec
- First Print Out Time Colour
- 6 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Scanning Resolution Details
- 1200 x 2400 dpi - flatbed , 1200 x 1200 dpi - ADF
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 550 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- E-mail function
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 64 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, B6 (125 x 176 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
- 330 sheets
- 830 sheets
- 80 sheets
- 150 sheets
- Input tray - 80 sheets size: 64 x 127 mm - 216 x 60000 mm weight: 64 g/m² - 256 g/m² , Input tray - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , ADF - 50 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 15 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 15 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 22 ipm - colour (ISO/IEC 24735) , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Scanning: up to 24 ipm - B/W , Scanning: up to 24 ipm - colour , Scanning: up to 8 ipm - B/W duplex , Scanning: up to 8 ipm - colour duplex
- 2 x USB host - 4 pin USB Type A , 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
- LDAP, SSL, Apple Bonjour, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows XP SP2 or later, MS Windows XP Professional x64 Edition, MS Windows XP SP3, MS Windows XP 64-bit Edition, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, Windows 8.1, MS Windows Server 2012 R2, MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 10, Apple Mac OS X 10.10.x, Apple Mac OS X 10.11.x, Apple Mac OS X 10.12.x
- Software Included
- Drivers & Utilities, Epson Document Capture Pro
- Voltage Required
- 25 Watt
- Power Consumption Standby
- 12 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 42.5 cm
- 53.5 cm
- 35.7 cm
- 18.4 kg
- Shipping Width
- 53.8 cm
- Shipping Depth
- 55.2 cm
- Shipping Height
- 53.7 cm
- Shipping Weight
- 23 kg
- Sound Emission
- 54 dBA (operating)
Epson WF-C5XXX SERIES INK XL BLACK | In Stock | £55.67 |
Epson WF-C5XXX SERIES INK L BLACK | In Stock | £31.63 |
Epson WF-C5XXX SERIES INK XL YELLOW | In Stock | £63.61 |
Epson WF-C5XXX SERIES INK L YELLOW | In Stock | £35.77 |
Epson WF-C5XXX SERIES INK XL MAGENTA | In Stock | £63.61 |
Epson WF-C5XXX SERIES INK L MAGENTA | In Stock | £35.77 |
Epson WF-C5XXX SERIES INK XL CYAN | In Stock | £63.61 |
Epson WF-C5XXX SERIES INK L CYAN | In Stock | £35.77 |
Epson WF-C5X90 SERIES INK XXL BLACK | In Stock | £102.11 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £11.87 |
