Brand
Epson WorkForce Pro WF-C5790DWF Colour Inkjet 34ppm Printer
Quicklinx: DD0ZWS00 Mfr#: C11CG02401BY
Functionality: Copier, Printer, Fax, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
£288.74 ex VAT
£346.48 inc VAT
This small workgroup multifunction device is perfect for the business environment, from small offices to large corporates who may have traditionally used lasers and want to cut costs, increase productivity and reduce downtime. This is while also cutting their business' environmental impact and improving their CSR reputation.
  • Fast, small workgroup MFD
    Reduce your business printing costs and environmental impact, all while increasing productivity with less intervention and enhanced security.
Epson WorkForce Pro WF-C5790DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
45000 pages
Recommended Monthly Volume
250 - 2500 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 22 ppm (colour)
Max Copying Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Copying Resolution Class
Max Printing Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
64 x 127 mm (min) - 216 x 60000 mm (max)
Media Type
Envelopes, plain paper, recycled paper, glossy photo paper
Standard Media Capacity
330 sheets
Max Media Capacity
830 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP
AC 120/230 V (50/60Hz)
42.5 cm x 53.5 cm x 35.7 cm
18.4 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
45000 pages
250 - 2500 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (black), 3 x 800 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.8 pl
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7, EPSON ESC/P-R
Automatic Duplexing
First Print Out Time B/W
5 sec
First Print Out Time Colour
6 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Scanning Resolution Details
1200 x 2400 dpi - flatbed , 1200 x 1200 dpi - ADF
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
E-mail function
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
64 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, B6 (125 x 176 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
330 sheets
Max Media Capacity
830 sheets
80 sheets
150 sheets
Input tray - 80 sheets size: 64 x 127 mm - 216 x 60000 mm weight: 64 g/m² - 256 g/m² , Input tray - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , ADF - 50 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 15 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 15 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 22 ipm - colour (ISO/IEC 24735) , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Scanning: up to 24 ipm - B/W , Scanning: up to 24 ipm - colour , Scanning: up to 8 ipm - B/W duplex , Scanning: up to 8 ipm - colour duplex
2 x USB host - 4 pin USB Type A , 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, Apple Bonjour, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows XP SP2 or later, MS Windows XP Professional x64 Edition, MS Windows XP SP3, MS Windows XP 64-bit Edition, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, Windows 8.1, MS Windows Server 2012 R2, MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 10, Apple Mac OS X 10.10.x, Apple Mac OS X 10.11.x, Apple Mac OS X 10.12.x
Software Included
Drivers & Utilities, Epson Document Capture Pro
25 Watt
Power Consumption Standby
12 Watt
Power Consumption Sleep
1.5 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - on-site
42.5 cm
53.5 cm
35.7 cm
18.4 kg
Shipping Width
53.8 cm
Shipping Depth
55.2 cm
Shipping Height
53.7 cm
Shipping Weight
23 kg
Sound Emission
54 dBA (operating)
DD0Z Epson A4 Glossy Photo Paper 20 Sheets In Stock £7.63
DD0Z Epson T9451 XL Size - Black Original Ink Cartridge In Stock £55.33
DD0Z Epson T9441 Black Original Ink Cartridge In Stock £31.93
DD0Z Epson T9454 XL Size - Yellow Original Ink Cartridge In Stock £67.18
DD0Z Epson T9444 L Size - Yellow Original Ink Cartridge In Stock £39.61
DD0Z Epson T9453 XL - Magenta Original Ink Cartridge In Stock £69.58
DD0Z Epson T9443 L Size - Magenta Original Ink Cartridge In Stock £39.41
DD0Z Epson T9452 XL - Cyan Original Ink Cartridge In Stock £69.58
DD0Z Epson T9442 Cyan Original Ink Cartridge In Stock £39.21
DD0Z Epson T9461 XXL Size - Black Original Ink Cartridge In Stock £99.84
DD0Z Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.61
DD0Z Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £11.37
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 34ppm
Max Paper Size: 216 x 60000 mm
Brand: Epson
