Epson WorkForce Pro WF-8590 D3TWFC Multifunction printer
Quicklinx: DFVQWS00 Mfr#: C11CD45301BX
Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO), and print up to 7,000 colour and 10,000 mono pages using easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
Uses up to 80% less power than competitive colour lasers thanks to the no heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the workplace. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8590D3TWFC delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results, and features one-pass duplex scanning and a 50-sheet Automatic Document Feeder. Scalable optional paper trays take its maximum capacity to 1,831 sheets.
Built for business
Epson's PrecisionCore technology powers the output quality and reliability at the speeds required for both office and industrial printing. A smartphone-like 12.7cm colour touchscreen is easy to use, while scan-to functions, including Microsoft SharePoint4, and LDAP address book compatibility make it ideal to share documents. Also securely print using a PIN code to release confidential documents, or use Email Print for Enterprise5 to securely send documents directly to the multifunction printer.
  • Ecological and low-TCO A3+ multifunction
    This A3+ business multifunction printer seamlessly integrates into medium to large enterprises. It cuts costs and environmental impact, reduces intervention, uses fewer supplies and has a scalable paper capacity.
  • Environmentally-friendly and low-intervention printing
    A small to medium workgroup A3+ multifunction printer that's perfect for business who have traditionally used lasers and want to cut costs, increase productivity and reduce downtime. Epson's clean technology helps create a more environmentally-friendly workplace, and PDL printer emulations and Gigabit Eithernet are ideal for enterprise integration.
  • Low total cost of ownership
    For cost-conscious offices this business printer saves money with its low total cost of ownership. It uses Epson's DURABrite Pro inks in easy-to-change, high-capacity cartridges of up to 7,000 colour and 10,000 mono pages , which ensure efficiency and productivity.
  • Ecological
    The WF-8590D3TWFC uses up to 80 percent less energy than competitive colour lasers thanks to its no-heat technology . No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment. And there are fewer consumables and parts to replace than a comparable laser.
  • Enhance productivity
    The lack of warm-up time helps this printer deliver fast and efficient business printing, with print speeds of up to 34ppm in both colour and mono, and 20ppm ISO print speeds in both . It delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results, and features one-pass duplex scanning and a 50-sheet Automatic Document Feeder. Scalable optional paper trays increase its maximum capacity to 1,831 sheets, meaning less time is spent refilling.
  • Easy to use
    Easily control the printer using its smartphone-like 12.7cm touch-screen. Automatic double-sided printing, scanning, copying and faxing as standard makes any job easy and means less paper is used too. In addition, front-loading ink cartridges are easy to change.
  • PrecisonCore technology
    PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. It's the use of PrecisionCore that aids printing onto a range of different media. Accordingly, the printer has a rear paper feed tray for A3+ and printing onto thicker card, envelopes and labels.
  • Built for business
    Its flexible connectivity allows this printer to seamlessly integrate into office networks. Wi-Fi and Wi-Fi Direct, PDL printer emulations, and Gigabit Ethernet all help to boost office productivity. PC-less scan-to functions, including Microsoft SharePoint using Document Capture Pro4, and scan-to-email with LDAP address book compatibility, make it ideal for sharing documents. Users can also securely print using a PIN code to release confidential documents.
  • Print from anywhere
    Stay connected and productive. Email Print for Enterprise5 allows you to securely send documents directly to the multifunction printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
Epson WorkForce Pro WF-8590 D3TWFC - multifunction printer - colour
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
65000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Printing Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 Plus (329 x 483 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
1830 sheets
Max Media Capacity
1831 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to Cloud
AC 230 V
59 cm x 57 cm x 58.9 cm
46.4 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
65000 pages
Display Features
Touch screen
AirPrint Enabled
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.7 pl
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c, EPSON ESC/P Raster, PDF 1.7
Ink Type
Epson DURABrite Pro inks
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, colour faxing, Duplex Fax
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
50 sheets
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, A3 Plus (329 x 483 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
1830 sheets
Max Media Capacity
1831 sheets
80 sheets
250 sheets
Input tray - 250 sheets , ADF - 50 sheets , Input tray - 80 sheets , Output tray - 250 sheets , 3 x input tray - 500 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 21 ipm - colour (ISO/IEC 24735) , Scanning: up to 23 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour , Scanning: 5 sec (A4) - B/W , Scanning: 7 sec (A4) - colour
1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later
Software Included
Epson Connect
AC 230 V
39 Watt
Power Consumption Standby
17 Watt
Power Consumption Sleep
2.4 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
59 cm
57 cm
58.9 cm
46.4 kg
Sound Emission
52 dBA (operating)
