Epson WorkForce Pro WF-8090DW A3+ Colour Inkjet Printer
Quicklinx: CCH6WS00 Mfr#: C11CD43301BY
Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO) and print up to 7,000 colour and 10,000 mono pages using, easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
The WF-8090DW uses up to 80 percent less power than competitive colour lasers thanks to its no heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the workplace. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8090DW delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results. Scalable optional paper trays take its maximum capacity to 1,831 sheets, and the rear manual paper tray lets you print A3+ and onto a range of media.
Built for business
PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. Wi-Fi and Wi-Fi Direct allow for easy integration and printing from smartphones and tablets. Users can also securely print using a PIN code to release jobs at the printer, or by using Email Print for Enterprise4 to securely send documents directly to the printer.
  • Ecological and low-TCO A3+ printer
    This A3+ business printer seamlessly integrates into medium to large enterprises. It cuts costs and environmental impact, reduces intervention, uses fewer supplies and has a scalable paper capacity.
  • Environmentally-friendly and low-intervention printing
    A small to medium workgroup A3+ printer that's perfect for businesses who have traditionally used lasers and want to cut costs, increase productivity and reduce downtime. Epson's clean technology helps create a more environmentally-friendly workplace, and PDL printer emulations and Gigabit Eithernet are ideal for enterprise integration.
  • Low total cost of ownership
    For cost-conscious offices this business printer saves money with its low total cost of ownership. It uses Epson's DURABrite Pro inks in easy-to-change, high-capacity cartridges of up to 7,000 colour and 10,000 mono pages , which ensure efficiency and productivity.
  • Ecological
    The WF-8090DW uses up to 80 percent less energy than competitive colour lasers thanks to its no-heat technology . No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment. And there are fewer consumables and parts to replace than a comparable laser.
  • Enhance productivity
    The lack of warm-up time helps this printer deliver fast and efficient business printing, with print speeds of up to 34ppm in both colour and mono, and 20ppm ISO print speeds in both . Automatic duplex A3 and A4 printing makes jobs easy and efficient, and reduces paper consumption. Scalable optional paper trays increase its maximum capacity to 1,831 sheets, meaning less time is spent refilling.
  • Easy to use
    Easily control the printer using its 5.6 mono LCD screen, and the front-loading ink cartridges are easy to change.
  • PrecisonCore technology
    PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. It's the use of PrecisionCore that aids printing onto a range of different media. Accordingly, the printer has a rear paper feed tray for A3+ and printing onto thicker card, envelopes and labels.
  • Built for business
    Its flexible connectivity allows this printer to seamlessly integrate into office networks. Wi-Fi and Wi-Fi Direct, PDL printer emulations, and Gigabit Ethernet all help to boost office productivity. Users can also securely print using a PIN code to release confidential documents.
  • Print from anywhere
    Stay connected and productive. Email Print for Enterprise4 allows you to securely send documents directly to the multifunction printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
Epson WorkForce Pro WF-8090DW - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
25.9 kg
Inkjet Technology
Epson PrecisionCore
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A3
Max Media Size
A3 Plus (329 x 483 mm)
Print Speed
Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - colour (ISO/IEC 24734) , Up to 16 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
Language Simulation
PCL 5E, PCL 5C, PostScript 3, PCL 6, EPSON ESC/P Raster, PDF 1.7
Media Type
Envelopes, plain paper
Total Media Capacity
330 sheets
Media Handling
250-sheet input tray, manual bypass slot, 80-sheet multipurpose tray
Monthly Duty Cycle (max)
65000 pages
Print server
AC 230V
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x
1-year warranty
56.7 cm x 57 cm x 37.8 cm
Printer Type
Printer
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
Minimum Ink Droplet Size
3.7 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Pro inks
Print Speed
Wireless
AirPrint Enabled
4800 x 1200 dpi
4800 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Language Simulation
Media Handling
Media Handling
Media Type
Media Size Class
A3
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, A3 Plus (329 x 483 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
330 sheets
Media Feeders
1 x automatic - 250 sheets , 1 x automatic - 80 sheets , 1 x manual - 1 sheet
Max Media Capacity
1831 sheets
Output Trays Capacity
250 sheets
Duty Cycle
65000 pages
Print server
Remote Management Protocol
SNMP, IPP, HTTP
Security Protocols & Features
SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, TKIP, AES, PING, Wi-Fi Direct
1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Power supply - internal
AC 230V
37 Watt
Power Consumption Stand by
8.1 Watt
Power Consumption Sleep
2.1 Watt
Limited warranty - 1 year - on-site
Sound Emission (Operating)
53 dBA
56.7 cm
57 cm
37.8 cm
25.9 kg
CCH6 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
CCH6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
CCH6 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.89
