Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO), and print up to 4,000 colour and 5,000 mono pages using, easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
The WF-8010DWF uses up to 80 percent less power than competitive colour lasers thanks to its no-heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the work environment. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8010DWF delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results. Scalable optional paper trays take its maximum capacity to 1,831 sheets, and the rear manual paper tray lets you print A3+ and onto a range of media.
Built for business
PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. With Gigabit Ethernet and Wi-Fi connectivity, the WF-8010DWF seamlessly integrates into any business network. Users can also securely print using a PIN code to release confidential documents, or by using Email Print for Enterprise4 to securely send documents directly to the printer.
Ecological and low-TCO A3+ printer
Ideal for small to medium offices that want to cut costs and environmental impact, and reduce intervention, this A3+ business printer uses fewer supplies and has a scalable paper capacity. -
Environmentally-friendly and low-intervention printing
A small to medium workgroup A3+ printer that's perfect for businesses who have traditionally used lasers and want to cut costs, increase productivity and reduce downtime. Epson's clean technology helps create a more environmentally-friendly workplace. -
Low total cost of ownership
For cost-conscious offices this business printer saves money with its low total cost of ownership. It uses Epson's DURABrite Pro inks in easy-to-change, high-capacity cartridges of up to 5,000 pages in black and 4,000 pages in colour, which ensure efficiency and productivity. -
Ecological
The WF-8010DW uses up to 80 percent less energy than competitive colour lasers thanks to its no-heat technology . No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the work environment. And there are fewer consumables and parts to replace than a comparable laser. -
The lack of warm-up time helps this printer deliver fast and efficient business printing, with print speeds of up to 34ppm in both colour and mono, and 20ppm ISO print speeds in both . Automatic duplex A3 and A4 printing makes jobs easy and efficient, and reduces paper consumption. Scalable optional paper trays increase its maximum capacity to 1,831 sheets, meaning less time is spent refilling. -
Easy to use
Easily control the printer using its 5.6 mono LCD screen, and the front-loading ink cartridges are easy to change. -
PrecisonCore technology
PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. It's the use of PrecisionCore that aids printing onto a range of different media,. Accordingly, the printer has a rear paper feed tray for A3+ and printing onto thicker card, envelopes and labels. -
Built for business
Its flexible connectivity allows this printer to seamlessly integrate into office networks. As well as Wi-Fi and Wi-Fi Direct, it features Gigabit Ethernet to ensure that print jobs are received quickly, at the speeds that businesses require. Users can also securely print using a PIN code to release confidential documents. -
Print from anywhere
Stay connected and productive. Email Print for Enterprise4 allows you to securely send documents directly to the multifunction printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
- Epson WorkForce Pro WF-8010DW - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 25.9 kg
- Inkjet Technology
- Epson PrecisionCore
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A3
- Max Media Size
- A3 Plus (329 x 483 mm)
- Print Speed
- Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - color (ISO/IEC 24734) , Up to 16 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 4800 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- Language Simulation
- Windows GDI driver
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 330 sheets
- Media Handling
- 250-sheet input tray, manual bypass slot, 80-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 65000 pages
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x
- 56.7 cm x 57 cm x 37.8 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
- Minimum Ink Droplet Size
- 3.7 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Pro inks
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 4800 x 1200 dpi
- 4800 x 1200 dpi
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 7 sec
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, A3 Plus (329 x 483 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 330 sheets
- Media Feeders
- 1 x automatic - 250 sheets , 1 x automatic - 80 sheets , 1 x manual - 1 sheet
- Max Media Capacity
- 1831 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 65000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP, IPP, HTTP
- SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, AES, PING, Wi-Fi Direct
- Connections
- 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- 37 Watt
- Power Consumption Stand by
- 8.1 Watt
- Power Consumption Sleep
- 2.1 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 53 dBA
- 56.7 cm
- 57 cm
- 37.8 cm
- 25.9 kg
- Width (Shipping)
- 73.1 cm
- Depth (Shipping)
- 70.3 cm
- Height (Shipping)
- 62.3 cm
- Weight (Shipping)
- 31.8 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.20 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.64 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.15 |
