Environmentally-conscious
With up to 80% lower energy consumption than competitive colour lasers , the WF-6590DWF cuts your environmental impact. Relying on clean technology, it produces no fan noise when not printing, no heat and no ozone gas.
Low running costs
With an up to 50% lower cost per page and a lower total cost of ownership compared to competitive colour laser printers , the WF-6590DWF will save businesses money. Duplex printing and copying also saves paper.
Less intervention and high reliability
Using Epson's XXL ink cartridges, you can print up to 10,000 pages in black and 7,000 pages in colour, which is equal to or better than colour laser equivalents4. The maximum paper capacity of 1,581 pages means less time spent refilling.
Fast printing and scanning
With a colour first page out time of just seven seconds , the WF-6590DWF is perfect for printing small print jobs quickly. Fast scan speeds and one-pass scanning make jobs even more efficient.
Advanced document management
IT departments can take full control, customising it to automate job profiles and workflow processes using Document CapturePro and ProServer software5 and connecting to most document management systems.
Smart control
Print and scan to the WF-6590DWF wirelessly with NFC pairing from Android smart devices, or email documents from remote locations for instant printing on the WF-6590DWF. Epson Device Admin makes it easy to manage a fleet of devices remotely.
Low-intervention printing
Save time, money and energy with this high-capacity colour 4-in-1 printer, offering increased productivity and reduced intervention for busy offices.
- Epson WorkForce Pro WF-6590DWF - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Monthly Duty Cycle (max)
- 65000 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Printing Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, bond paper
- Standard Media Capacity
- 580 sheets
- Max Media Capacity
- 1581 sheets
- Bypass Feeder Capacity
- 80 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to Cloud
- Power
- AC 230 V
- 51.6 cm x 52.2 cm x 51.4 cm
- 31 kg
- Fax Type
- Plain paper
- Ink-jet - colour
- 65000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Inkjet Technology
- Nozzle Configuration
- 800 nozzles (per cartridge)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.7 pl
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF 1.7, EPSON ESC/P-R
- Ink Type
- Epson DURABrite Pro inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 550 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Automatic redialing, colour faxing
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 580 sheets
- 1581 sheets
- 80 sheets
- 250 sheets
- Input tray - 500 sheets , ADF - 50 sheets , Input tray - 80 sheets , Bypass tray - 1 sheet , Output tray - 250 sheets
- Speed Details
- Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 21 ipm - colour (ISO/IEC 24735) , Scanning: up to 23 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP, SSL, WEP, WPA-PSK, IPsec, 802.1x, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
- Voltage Required
- AC 230 V
- 39 Watt
- Power Consumption Standby
- 17 Watt
- Power Consumption Sleep
- 2.4 Watt
- Consumables Included
- 1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
- 51.6 cm
- 52.2 cm
- 51.4 cm
- 31 kg
- Sound Emission
- 50 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £12.88 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £9.84 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £12.30 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £11.87 |
