Epson WorkForce Pro WF-6590DWF Multifunction Printer
Quicklinx: BSVXWS00 Mfr#: C11CD49301BY
Environmentally-conscious
With up to 80% lower energy consumption than competitive colour lasers , the WF-6590DWF cuts your environmental impact. Relying on clean technology, it produces no fan noise when not printing, no heat and no ozone gas.
Low running costs
With an up to 50% lower cost per page and a lower total cost of ownership compared to competitive colour laser printers , the WF-6590DWF will save businesses money. Duplex printing and copying also saves paper.
Less intervention and high reliability
Using Epson's XXL ink cartridges, you can print up to 10,000 pages in black and 7,000 pages in colour, which is equal to or better than colour laser equivalents4. The maximum paper capacity of 1,581 pages means less time spent refilling.
Fast printing and scanning
With a colour first page out time of just seven seconds , the WF-6590DWF is perfect for printing small print jobs quickly. Fast scan speeds and one-pass scanning make jobs even more efficient.
Advanced document management
IT departments can take full control, customising it to automate job profiles and workflow processes using Document CapturePro and ProServer software5 and connecting to most document management systems.
Smart control
Print and scan to the WF-6590DWF wirelessly with NFC pairing from Android smart devices, or email documents from remote locations for instant printing on the WF-6590DWF. Epson Device Admin makes it easy to manage a fleet of devices remotely.
  • Low-intervention printing
    Save time, money and energy with this high-capacity colour 4-in-1 printer, offering increased productivity and reduced intervention for busy offices.
Epson WorkForce Pro WF-6590DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
65000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Printing Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, bond paper
Standard Media Capacity
580 sheets
Max Media Capacity
1581 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to Cloud
AC 230 V
51.6 cm x 52.2 cm x 51.4 cm
31 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
65000 pages
Display Features
Touch screen
AirPrint Enabled
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.7 pl
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF 1.7, EPSON ESC/P-R
Ink Type
Epson DURABrite Pro inks
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, colour faxing
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
580 sheets
Max Media Capacity
1581 sheets
80 sheets
250 sheets
Input tray - 500 sheets , ADF - 50 sheets , Input tray - 80 sheets , Bypass tray - 1 sheet , Output tray - 250 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 21 ipm - colour (ISO/IEC 24735) , Scanning: up to 23 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, WEP, WPA-PSK, IPsec, 802.1x, Wi-Fi Direct
Operating System Support
Linux, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
AC 230 V
39 Watt
Power Consumption Standby
17 Watt
Power Consumption Sleep
2.4 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
51.6 cm
52.2 cm
51.4 cm
31 kg
Sound Emission
50 dBA (operating)
BSVX Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £14.96
BSVX Epson Ultra Glossy Photo Paper 10x15 50 Sheets In Stock £10.58
BSVX Epson A4 Glossy Photo Paper 20 Sheets In Stock £9.58
BSVX Epson Glossy Photo Paper 50 Sheets In Stock £8.10
BSVX Epson Glossy Photo Paper 50 Sheets In Stock £6.99
BSVX Epson Glossy Photo Paper 200 Sheets In Stock £31.39
BSVX Epson A4 Glossy Photo Paper 50 Sheets In Stock £18.71
BSVX Epson Maintenance Box for WorkForce Pro In Stock £25.83
BSVX Epson Cartridge Workforce PRO WF-6XX In Stock £66.47
BSVX Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.37
BSVX Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.69
BSVX Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £14.06
