Epson Workforce Pro WF-6090DW A4 Colour Printer
Quicklinx: CCHNWS00 Mfr#: C11CD47301BY
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
£382.82 ex VAT
£459.38 inc VAT
Environmentally-conscious
With up to 80% lower energy consumption than competitive colour lasers , the WF-6090DW cuts your environmental impact. Relying on clean technology, it produces no fan noise when not printing, no heat and no ozone gas.
Low running costs
With an up to 50% lower cost per page and a lower total cost of ownership compared to competitive colour laser printers , the WF-6090DW will save businesses money. With colour duplex printing, it also saves paper.
Less intervention and high reliability
Using Epson's XXL ink cartridges, the WF-6090DW can print up to 10,000 pages in black and 7,000 pages in colour, which is equal to or better than colour laser equivalents4. The maximum paper capacity of 1,581 pages means less time spent refilling.
Fast printing
With a colour first page out time of just seven seconds , the WF-6090DW is perfect for printing small print jobs quickly.
Smart control
Print to the WF-6090DW wirelessly with NFC pairing from Android smart devices, or email documents from remote locations for instant printing on the WF-6090DW. Epson Device Admin makes it easy to manage a fleet of devices remotely.
  • Low-intervention printing
    Offering increased productivity and reduced intervention for busy offices, this high-capacity colour printer save time, money and energy.
Epson WorkForce Pro WF-6090DW - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
28 kg
Inkjet Technology
Epson PrecisionCore
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - color (ISO/IEC 24734) , Up to 16 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), NFC
AirPrint Enabled
Language Simulation
PCL 5E, PCL 5C, PostScript 3, PCL 6, EPSON ESC/P Raster, PDF 1.7
Media Type
Envelopes, plain paper
Total Media Capacity
580 sheets
Media Handling
500-sheet input tray, 1-sheet manual tray, 80-sheet multipurpose tray
Monthly Duty Cycle (max)
65000 pages
Print server
AC 230V
Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x
47.8 cm x 52.2 cm x 40.4 cm
Printer Type
Printer
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (per cartridge)
Minimum Ink Droplet Size
3.7 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Pro inks
Print Speed
Wireless
AirPrint Enabled
4800 x 1200 dpi
4800 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Language Simulation
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
580 sheets
Media Feeders
1 x automatic - 500 sheets , 1 x automatic - 80 sheets , 1 x manual - 1 sheet
Max Media Capacity
1581 sheets
Output Trays Capacity
250 sheets
Duty Cycle
65000 pages
Print server
Remote Management Protocol
SNMP, IPP, HTTP
Security Protocols & Features
SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, TKIP, AES, PING, Wi-Fi Direct
1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Power supply - internal
AC 230V
37 Watt
Power Consumption Stand by
8.1 Watt
Power Consumption Sleep
2.1 Watt
Sound Emission (Operating)
49 dBA
47.8 cm
52.2 cm
40.4 cm
28 kg
Ink (4)
CCHN Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £14.04
CCHN Epson Matte Paper Heavyweight A4 50 sheets In Stock £10.12
CCHN Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £12.77
CCHN Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £12.17
Other bundles (4)
CCHN C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
CCHN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
CCHN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.36
CCHN C2G 2m Cat6a Shielded Patch - Blue In Stock £7.62
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Epson
Price Range Ex VAT: 300 - 500
