Increase the productivity of your office with the exceedingly fast, yet compact WF-4740DTWF. With a 500 sheet capacity, 50 page ADF and PrecisonCore technology, this 4-in-1 with double-sided print, scan, copy and fax can cater for the busiest office. It's easy to use too with NFC, Wi-Fi, Wi-Fi Direct and Epson's mobile printing apps. And print up to 2,600 pages in black with XL inks.
Fast, duplex, business 4-in-1
Supercharge the office with this compact yet fast and cost-effective 4-in-1 with double-sided printing, duplex ADF and 10.9cm touchscreen.
- Epson WorkForce Pro WF-4740DTWF - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Max Printing Speed
- Up to 24 ppm (mono) / up to 22 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 500 sheets
- Output Trays Capacity
- 80 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Power
- AC 120/230 V (50/60Hz)
- 42.5 cm x 38.8 cm x 33 cm
- 12.1 kg
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
Printing
- Inkjet Technology
- Nozzle Configuration
- 800 nozzles (per cartridge)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.8 pl
- Printer Drivers / Emulations
- EPSON ESC/P-R
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 180 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 100 station(s)
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 500 sheets
- 80 sheets
- Input tray - 500 sheets , ADF - 50 sheets , Output tray - 80 sheets
- Speed Details
- Printing: up to 34 ppm - B/W , Printing: up to 30 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 22 ppm - colour (ISO/IEC 24734) , Printing: up to 14 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 14 ppm (A4) - colour duplex (ISO/IEC 24734)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8 64-bit
- Software Included
- Drivers & Utilities
- Voltage Required
- 20 Watt
- Power Consumption Standby
- 8.9 Watt
- Power Consumption Sleep
- 1.2 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Limited warranty - 1 year - on-site
- 42.5 cm
- 38.8 cm
- 33 cm
- 12.1 kg
Epson Multi 4-Colour 35XL Durabrite Ultra | In Stock | £121.62 |
Epson Singlepack Black 35 DURABrite Ultra Ink | In Stock | £25.62 |
Epson Multipack 4 Colours 35 DURABrite Ultra Ink | In Stock | £71.30 |
