Epson Workforce Pro WF-4740DTWF
Quicklinx: D65QWS00 Mfr#: C11CF75401
Increase the productivity of your office with the exceedingly fast, yet compact WF-4740DTWF. With a 500 sheet capacity, 50 page ADF and PrecisonCore technology, this 4-in-1 with double-sided print, scan, copy and fax can cater for the busiest office. It's easy to use too with NFC, Wi-Fi, Wi-Fi Direct and Epson's mobile printing apps. And print up to 2,600 pages in black with XL inks.
  • Fast, duplex, business 4-in-1
    Supercharge the office with this compact yet fast and cost-effective 4-in-1 with double-sided printing, duplex ADF and 10.9cm touchscreen.
Epson WorkForce Pro WF-4740DTWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
25000 pages
Max Printing Speed
Up to 24 ppm (mono) / up to 22 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
500 sheets
Output Trays Capacity
80 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
AC 120/230 V (50/60Hz)
42.5 cm x 38.8 cm x 33 cm
12.1 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
25000 pages
Display Features
Touch screen
AirPrint Enabled
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.8 pl
Printer Drivers / Emulations
EPSON ESC/P-R
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
500 sheets
80 sheets
Input tray - 500 sheets , ADF - 50 sheets , Output tray - 80 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 30 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 22 ppm - colour (ISO/IEC 24734) , Printing: up to 14 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 14 ppm (A4) - colour duplex (ISO/IEC 24734)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
20 Watt
Power Consumption Standby
8.9 Watt
Power Consumption Sleep
1.2 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Limited warranty - 1 year - on-site
42.5 cm
38.8 cm
33 cm
12.1 kg
D65Q Epson Multi 4-Colour 35XL Durabrite Ultra In Stock £121.10
D65Q Epson Singlepack Black 35 DURABrite Ultra Ink In Stock £25.62
D65Q Epson Multipack 4 Colours 35 DURABrite Ultra Ink In Stock £76.01
