Epson WorkForce Pro WF-4630DWF A4 Colour Multifunction Printer
Quicklinx: 9H8FWS00 Mfr#: C11CD10301BY
Save time and money
It offers up to a 50 percent lower cost per page compared to competitive colour lasers, and saves you time, being faster than a laser on typical print jobs , with no warm-up period. The WF-4630DWF uses up to 80 percent less power than competitive colour lasers .
High performance
Its high-yield cartridges are low maintenance and its 20ppm print speed in black and colour means you can print quickly with a print resolution of up to 4800x1200dpi. The paper capacity of up to 330 sheets means you won't need to spend time refilling.
Built for business
This inkjet printer has a monthly duty cycle of 30,000 pages4. Prints dry fast thanks to the DURABrite Ultra ink, meaning faster print speeds when printing double sided.
Flexible and easy to use
Its intuitive touch-screen makes functions readily available, and the rear manual paper tray lets you print on a range of media. It supports Epson Connect5, so you can easily print from smartphones, tablets and more. Its Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router. Document Capture Pro compatibility offers seamless integration into most document management systems.
PrecisionCore
PrecisionCore, Epson's most advanced printhead technology, powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing.
  • Save time and money
    It offers up to a 50 percent lower cost per pagecompared to competitive color lasers, and saves you time, being faster than a laser on typical print jobs³, with no warm-up period. The WF-4630DWF uses up to 80 percent less power than competitive color lasers³.
  • High performance
    Its high-yield cartridges are low maintenance and its 20ppm print speed in black and color¹ means you can print quickly with a print resolution of up to 4800x1200dpi. The paper capacity of up to 330 sheets means you won’t need to spend time refilling.
  • Built for business
  • Flexible and easy to use
  • PrecisionCore
    PrecisionCore, Epson’s most advanced printhead technology, powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing.
Epson WorkForce Pro WF-4630DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
30000 pages
Max Printing Speed
Up to 34 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
330 sheets
Max Media Capacity
330 sheets
Bypass Feeder Capacity
80 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to Cloud
AC 110/230 V (50/60Hz)
46.1 cm x 42.2 cm x 34.2 cm
14.2 kg
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
Display Features
Touch screen
AirPrint Enabled
Scan to Cloud
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Copying Features
Fit to page
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2.8 pl
Printer Drivers / Emulations
EPSON ESC/P Raster
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, colour faxing
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
330 sheets
Max Media Capacity
330 sheets
80 sheets
Input tray - 250 sheets , Bypass tray - 80 sheets , ADF - 35 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 30 ppm - colour , Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - color (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - colour duplex (ISO/IEC 24734)
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.6 or later
Software Included
Drivers & Utilities, Epson Document Capture Pro
20 Watt
Power Consumption Standby
7.5 Watt
Power Consumption Sleep
1.8 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
46.1 cm
42.2 cm
34.2 cm
14.2 kg
Ink (4)
9H8F Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £13.08
9H8F Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.51
9H8F Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.51
9H8F Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £11.89
Other bundles (4)
9H8F C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
9H8F C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
9H8F C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.47
9H8F C2G 2m Cat6a Shielded Patch - Blue In Stock £7.05
