Performance and productivity
This scanner features a compact footprint and high speed scanning of up to 65ppm / 130ipm, even at 300dpi in colour. This, combined with hardware JPEG compression, makes large scan jobs faster to process. Its ReadyScan technology certifies mercury-free products and guarantees no warm-up time before scanning.
Seamless integration into document management and cloud systems
Epson Document Capture Pro makes it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document filing system. In addition, barcode recognition and Zonal OCR help automate large document processes. It can also Push Scan from the device, via network or USB, which helps to increase office productivity.
Scan software included
Epson Scan offers a wide selection of advanced document imaging features, such as text enhancement and automatic de-skew, which help improve efficiency and increase workload output. It also scans to .docx, .xlsx and .pptx.
Easy network sharing via Ethernet
Combined with Document Capture Pro, the Network Interface Unit allows you to customise 'scan to' job commands, such as 'scan-to-email', 'scan-to-Microsoft SharePoint ' or 'Scan-to-Cloud', among others, directly from the scanner's panel.
Productive A4 sheet-fed scanner
The WorkForce DS-860N with Network Interface Unit is our fastest double-sided A4 sheet-fed scanner.
- Epson WorkForce DS-860N - document scanner - desktop - LAN
- Document scanner - desktop
- Interface Type
- LAN
- Light Source
- LED
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 65 ppm (mono) / 65 ppm (colour)
- Max Document Size
- 216 mm x 356 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- Duty Cycle
- 6000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
- 30 cm x 16.6 cm x 15.8 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- LAN
- A4 (210 x 297 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 65 ppm
- Max Document Scan Speed Colour
- 65 ppm
- Duty Cycle
- Scanner Speed Details
- 65 ppm - black & white - A4 - 300 dpi , 130 ipm - duplex - black & white - A4 - 300 dpi , 65 ppm - colour - A4 - 300 dpi , 130 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Automatic
- 80 sheets
- USB 2.0 - Type B
- Included Accessories
- Network interface panel
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- EPSON Scan, EPSON Document Capture Pro
- OS Required
- 30 cm
- 16.6 cm
- 15.8 cm
- 4 kg
- 5 °C
- 35 °C
