Productive A4 sheet-fed scanner
The WorkForce DS-860 is our fastest double-sided A4 sheet-fed scanner, ideal for governments, banks and healthcare establishments.
- Epson WorkForce DS-860 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Light Source
- LED
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 65 ppm (mono) / 65 ppm (colour)
- Max Document Size
- 216 mm x 356 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- Duty Cycle
- 6000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
- Microsoft Certification
- Compatible with Windows 7
- 30 cm x 16.6 cm x 15.8 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- A4 (210 x 297 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 65 ppm
- Max Document Scan Speed Colour
- 65 ppm
- Duty Cycle
- Scanner Speed Details
- 65 ppm - black & white - A4 - 300 dpi , 130 ipm - duplex - black & white - A4 - 300 dpi , 65 ppm - colour - A4 - 300 dpi , 130 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Automatic
- 80 sheets
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- EPSON Scan, EPSON Document Capture Pro
- OS Required
- 30 cm
- 16.6 cm
- 15.8 cm
- 4 kg
- 5 °C
- 35 °C
