EPSON WorkForce DS-860 High Speed Scanner Kofax VRS Certified
Quicklinx: 9FSCWS00 Mfr#: B11B222401BY
Easy network sharing via Ethernet
Optional Network Interface Unit is also available.
  • Productive A4 sheet-fed scanner
    The WorkForce DS-860 is our fastest double-sided A4 sheet-fed scanner, ideal for governments, banks and healthcare establishments.
Epson WorkForce DS-860 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Light Source
LED
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
65 ppm (mono) / 65 ppm (colour)
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
Microsoft Certification
Compatible with Windows 7
30 cm x 16.6 cm x 15.8 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
65 ppm
Max Document Scan Speed Colour
65 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
65 ppm - black & white - A4 - 300 dpi , 130 ipm - duplex - black & white - A4 - 300 dpi , 65 ppm - colour - A4 - 300 dpi , 130 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
80 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
Software Included
EPSON Scan, EPSON Document Capture Pro
30 cm
16.6 cm
15.8 cm
4 kg
5 °C
35 °C
