Epson WorkForce DS-780N Document scanner Duplex A4 600dpi
Quicklinx: D2NMWS00 Mfr#: B11B227401BY
£687.57 ex VAT
£825.08 inc VAT
Fast, high-volume scanning
The DS-780N is designed for high-volume network scanning, with a 100-sheet automatic document feeder (ADF), very fast colour scanning speeds of 45ppm/90ipm at 300dpi, and USB 3.0 to enable direct-to-PC connection.
Smart features improve workflow
Innovative features make scanning easy, including industry first slow mode for delicate documents and double-feed detection skip to allow scanning of items such as envelopes and documents with Post-its. An intuitive colour LCD touchscreen panel makes scanning easy, and allows job creation without accessing a computer.
Built-in networking and security features
The DS-780N with built-in networking is the perfect solution for creating a scanner fleet. Epson's Document Capture Pro 2.0 software offers complete control and security, allowing job, group, device and access protocols to be managed centrally. User authentication can be enabled via pin code, third-party IC card or user directory (LDAP), with a lockable control panel to prevent tampering. Pre-defined job profiles help ensure scans are sent to the correct locations.
Usage reports and maintenance alerts
Using Epson Device Admin or Document Capture Pro Server, the DS-780N can alert the administrator if it needs maintenance, and provides detailed usage reports showing which devices are used most and how many scans they've made, for effective fleet management.
  • Secure scanning
    Complete controlIntelligent, secure business scanner with built-in networking and smart features for fast, high-volume scanning and circulation.
Epson WorkForce DS-780N - document scanner - desktop - USB 3.0, Gigabit LAN
Document scanner - desktop
Interface Type
Additional Functions
Scan to network share, scan to FTP, scan to SharePoint, scan to email
Max Supported Document Size
A4 (210 x 297 mm)
United Kingdom
Input Type
Grayscale / Color Depth
10-bit grey / 30-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
45 ppm (mono) / 45 ppm (colour)
Max Document Size
215.9 mm x 6096 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
5000 scans per day
Linux, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
29.6 cm x 21.2 cm x 21.7 cm
3.7 kg
1-year warranty
Interface Type
A4 (210 x 297 mm)
United Kingdom
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
45 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
45 ppm - black & white - A4 - 300 dpi , 90 ipm - duplex - black & white - A4 - 300 dpi , 45 ppm - colour - A4 - 300 dpi , 90 ipm - duplex - colour - A4 - 300 dpi , 45 ppm - black & white - A4 - 200 dpi , 90 ipm - duplex - black & white - A4 - 200 dpi , 45 ppm - colour - A4 - 200 dpi , 90 ipm - duplex - colour - A4 - 200 dpi
Scanner Features
EPSON ReadyScan LED Technology, Barcode Detection, blank page skipping, built-in LCD screen, Auto Deskew, Punch Hole Removal, A3 stitching, automatic folder creation, automatic multi-document recognition, Unsharp Mask
Scan File Formats
JPEG, TIFF, PDF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 6096 mm
Automatic
100 sheets
Interfaces Details
USB 3.0 , Gigabit LAN
1 x USB cable
Internal power supply
Power Consumption Operational (Standby)
17 Watt
Power Consumption Stand by
1.3 Watt
Software Included
EPSON Document Capture Pro, EPSON Document Capture, EPSON Scan 2
29.6 cm
21.2 cm
21.7 cm
3.7 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 80%
