Epson WorkForce DS-770 Colour Duplex 45ppm Document Scanner
Quicklinx: D7H9WS00 Mfr#: B11B248401BY
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 3.0
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 1 left in stock!
£458.07 ex VAT
£549.68 inc VAT
Intelligent features improve efficiency, accuracy and data reliability
With an industry-first slow mode for scanning crumpled or fragile documents, the ability to scan challenging media has never been easier. The Active Separation Roller System prevents tedious document double feeds ensuring every piece of paper gets scanned and the Double Feed Detection Skip (DFDS) function means you can scan difficult media like envelopes or documents with post-it notes. Auto Scan Mode enables the processing of a vast number of documents as manageable amounts, enabling them to be scanned as one file.
Highly versatile
The optional flatbed scanner conversion kit allows effective document processing from stamps to passports and books. Single-pass double-sided scanning ensures rapid document processing, while it's possible to scan a versatile array of media such as paper as thin as 27gsm, or thick card at 413gsm. The A3 carrier sheet speeds up the process by automatically stitching larger documents back together digitally.
Flexible connectivity
High-speed USB 3.0 with TWAIN, WIA and ISIS drivers for enhanced compatibility with Document Management Systems.
Image enhancement and document management software
Epson Scan 2.0 software makes it easy to edit images with features such as de-skew and auto rotate, while Document Capture Pro is the easy to use solution for capturing and storing electronic documents at the touch of a button.
  • Innovative business scanner
    Intelligent compact sheet-fed scanner with innovative smart features to ensure the highly-efficient scanning of many documents quickly.
Epson WorkForce DS-770 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Additional Functions
Scan to print, scan to network share, scan to FTP, scan to folder, scan to SharePoint, scan to email
Max Supported Document Size
A4 (210 x 297 mm)
United Kingdom
Input Type
Grayscale / Color Depth
10-bit grey / 30-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
45 ppm (mono) / 45 ppm (colour)
Max Document Size
215.9 mm x 6096 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
5000 scans per day
Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Microsoft Windows Server 2012 (64-bit), Microsoft Windows XP Professional 64-bit Edition
29.6 cm x 16.9 cm x 17.6 cm
3.6 kg
1-year warranty
Perfection V19
Interface Type
USB 3.0
A4 (210 x 297 mm)
United Kingdom
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
45 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
45 ppm - black & white - A4 - 300 dpi , 90 ipm - duplex - black & white - A4 - 300 dpi , 45 ppm - colour - A4 - 300 dpi , 90 ipm - duplex - colour - A4 - 300 dpi , 45 ppm - black & white - A4 - 200 dpi , 90 ipm - duplex - black & white - A4 - 200 dpi , 45 ppm - colour - A4 - 200 dpi , 90 ipm - duplex - colour - A4 - 200 dpi
Scanner Features
EPSON ReadyScan LED Technology, Barcode Detection, blank page skipping, built-in LCD screen, Auto Deskew, Punch Hole Removal, A3 stitching, automatic folder creation, automatic multi-document recognition, Unsharp Mask
Scan File Formats
JPEG, TIFF, PDF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 6096 mm
Automatic
100 sheets
USB 3.0
1 x USB cable
Software Included
EPSON Document Capture Pro, EPSON Document Capture, EPSON Scan 2
29.6 cm
16.9 cm
17.6 cm
3.6 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 80%
Epson Perfection V19
Interface: USB 3.0
Compatibility: PC
Brand: Epson
Price Range Ex VAT: 300 - 500
