Epson WorkForce DS-530N Networked Sheetfed A4 Document Scanner
Quicklinx: CPTPWS00 Mfr#: B11B226401BU
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: Gigabit LAN, USB 3.0
Compatibility: Mac, PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£703.20 ex VAT
£843.84 inc VAT
Intelligent features improve efficiency, accuracy and data reliability
With an industry-first slow mode for scanning crumpled or fragile documents, the ability to scan challenging media has never been easier. The Active Separation Roller System prevents tedious document double feeds ensuring every piece of paper gets scanned and the Double Feed Detection Skip (DFDS) means you can scan difficult media like envelopes or documents with post-it notes. Auto Scan Mode enables the processing of a vast number of documents as manageable amounts, enabling them to be scanned as one file.
Highly versatile
The optional flatbed scanner conversion kit allows effective document processing from stamps to passports and books. Single-pass double-sided scanning ensures rapid document processing, while it's possible to scan a versatile array of media such as paper as thin as 27gsm, or thick card at 413gsm. The A3 carrier sheet speeds up the process by automatically stitching larger documents back together digitally.
Flexible connectivity
High-speed USB 3.0 with TWAIN and ISIS drivers for enhanced compatibility with Document Management Systems.
Image enhancement and document management software
Epson Scan 2.0 software makes it easy to edit images with features such as de-skew and auto rotate, while Document Capture Pro is the easy to use solution for capturing and storing electronic documents at the touch of a button.
  • Innovative business scanner
    Intelligent sheetfed document scanner with network capability, transforming workflows with smart features for capturing a wide range of documents.
Epson WorkForce DS-530N - document scanner - desktop - USB 3.0, Gigabit LAN
Document scanner - desktop
Interface Type
Light Source
LED
Additional Functions
Email, scan to print, scan to network share, scan to FTP, scan to folder, scan to SharePoint
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
35 ppm (mono) / 35 ppm (colour)
Max Document Size
216 mm x 6096 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
4000 scans per day
Linux, Apple MacOS X, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Microsoft Windows Server 2012 (64-bit)
29.6 cm x 16.9 cm x 17.6 cm
3.7 kg
1-year warranty
Interface Type
A4 (210 x 297 mm)
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
35 ppm
Max Document Scan Speed Colour
35 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
35 ppm - black & white - A4 - 300 dpi , 70 ipm - duplex - black & white - A4 - 300 dpi , 35 ppm - colour - A4 - 300 dpi , 70 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, Barcode Detection, blank page skipping, Text Enhancement, skew correction, auto image rotation, automatic folder creation, automatic multi-document recognition, Unsharp Mask
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 6096 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 6096 mm
Automatic
50 sheets
USB 3.0 , Gigabit LAN
1 x SuperSpeed USB cable
Software Included
EPSON Scan, Presto! BizCard 5.6, EPSON Document Capture Pro, EPSON Document Capture, EPSON Document Capture Pro Server
29.6 cm
16.9 cm
17.6 cm
3.7 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 80%
Interface: USB 3.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: 500 - 750
