Epson WorkForce DS-520N A4 Colour Networked Sheetfed Scanner
Quicklinx: B779WS00 Mfr#: B11B234401BU
High-speed scanner
The DS-520N has a compact footprint and high-speed scanning of up to 30ppm / 60ipm, even at 300dpi in both color and monochrome. This, combined with hardware JPEG compression, makes large scan jobs faster to process. With the Network Interface Unit, it is ideal for sharing across office and department networks.
Document workflow
Epson Document Capture Pro software¹ makes it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document repositories. Benefit from Push Scanning with pre-defined job profiles. In addition, barcode recognition and Zonal OCR will help automate large document processes, such as file naming and folder creation. It's easy to integrate thanks to TWAIN, ISIS and WIA driver support.
Efficient
Epson 's scanning software offers a wide range of advanced document imaging features, including multi-document size detection, text enhancement and automatic de-skew to improve efficiency and increase productivity.
Network sharing}
Easily integrate this network-ready model into your company environment. Combined with Document Capture Pro/Pro Server¹, this scanner increases productivity with customisable PushScan functions from the scanner panel such as scan-to Microsoft SharePoint and cloud services.
  • A4 networked scanner
    This high-speed sheet-fed scanner has network capability and Document Capture Pro for automatic distribution to document management systems.
Epson WorkForce DS-520N - document scanner - desktop - USB 2.0, Gigabit LAN
Document scanner - desktop
Interface Type
Light Source
LED
Additional Functions
Email, scan to network share, scan to FTP
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 914 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8
29.7 cm x 15.2 cm x 15.4 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
30 ppm - black & white - A4 - 300 dpi , 60 ipm - duplex - black & white - A4 - 300 dpi , 30 ppm - colour - A4 - 300 dpi , 60 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, Ultrasonic multifeed sensor, A3 stitching
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 914 mm
Automatic
50 sheets
USB 2.0 - Type B , Gigabit LAN
Network interface panel
1 x USB cable
ENERGY STAR Certified
Power Consumption Operational (Standby)
18 Watt
Power Consumption Stand by
16 Watt
Software Included
Drivers & Utilities, EPSON Scan, Presto! BizCard 6, EPSON Document Capture Pro, Presto! BizCard 7
29.7 cm
15.2 cm
15.4 cm
2.9 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Sound Emission
62 dBA
