The DS-410 provides a range of invaluable productivity features including double feed detection and paper protection technology to make sure originals are protected and every page is scanned. A set of advanced LED sensors detects when two pieces of paper have been picked at once, instantly stopping the machine and alerting the user. Meanwhile paper protection helps prevent misfeeds and damage by stopping automatically when the device detects stapled or skewed documents.
It has automatic feed mode for fast and simple scanning - just insert sheets and the scanner will begin, while a 50-sheet automatic document feeder makes it easy to scan large piles of documents.
The DS-410 has a robust build to handle everything office life can throw at it, and a very compact body to take up minimal desk space, so it's easy to fit into even the smallest of offices. It can scan at speeds of up to 26ppm/52ipm, and handle paper weights from 50g/m to 209g/m . Also, manual A3 mode allows ad-hoc scanning of larger-format originals.
The scanner is bundled with Epson's new Document Capture Pro 2.0 software, which offers a simple but powerful software solution for scanning, separating and routing documents throughout a business.
A4 sheet-fed business scanner
Innovative sheet-fed scanner with image enhancement technology, offering excellent productivity features at an affordable price.
- Epson WorkForce DS-410 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 26 ppm (mono) / 26 ppm (colour)
- Max Document Size
- 216 mm x 3048 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 3000 scans per day
- Power
- AC 120/230 V (50 - 60 Hz)
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Microsoft Windows Server 2003 R2 (64-bit), Windows 10, Apple MacOS X 10.10.x, Apple MacOS X 10.11.x, Apple MacOS X 10.11, Apple macOS 10.12
- 29.7 cm x 15.2 cm x 15.4 cm
- 2.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- A4 (210 x 297 mm)
Scanner
- Input Type
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 26 ppm
- Max Document Scan Speed Colour
- 26 ppm
- Duty Cycle
- Scanner Speed Details
- 26 ppm - black & white - A4 - 300 dpi , 26 ppm - colour - A4 - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology, Barcode Detection, blank page skipping, Text Enhancement, Auto Document Rotation, A3 stitching
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 3048 mm
- Plain paper
- Automatic
- 50 sheets
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 15 Watt
- Power Consumption Stand by
- 4.1 Watt
- Power Consumption Sleep
- 0.6 Watt
- Software Included
- EPSON Scan 2, EPSON Document Capture Pro 2.0
- OS Required
- 29.7 cm
- 15.2 cm
- 15.4 cm
- 2.5 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 15 - 80%
