Epson WorkForce DS-410 Document scanner Duplex A4 600 dpi 26ppm
Quicklinx: D6SGWS00 Mfr#: B11B249401PU
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0
17 in stock
£300.70 ex VAT
£360.84 inc VAT
The DS-410 provides a range of invaluable productivity features including double feed detection and paper protection technology to make sure originals are protected and every page is scanned. A set of advanced LED sensors detects when two pieces of paper have been picked at once, instantly stopping the machine and alerting the user. Meanwhile paper protection helps prevent misfeeds and damage by stopping automatically when the device detects stapled or skewed documents.
It has automatic feed mode for fast and simple scanning - just insert sheets and the scanner will begin, while a 50-sheet automatic document feeder makes it easy to scan large piles of documents.
The DS-410 has a robust build to handle everything office life can throw at it, and a very compact body to take up minimal desk space, so it's easy to fit into even the smallest of offices. It can scan at speeds of up to 26ppm/52ipm, and handle paper weights from 50g/m to 209g/m . Also, manual A3 mode allows ad-hoc scanning of larger-format originals.
The scanner is bundled with Epson's new Document Capture Pro 2.0 software, which offers a simple but powerful software solution for scanning, separating and routing documents throughout a business.
  • A4 sheet-fed business scanner
    Innovative sheet-fed scanner with image enhancement technology, offering excellent productivity features at an affordable price.
Epson WorkForce DS-410 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
26 ppm (mono) / 26 ppm (colour)
Max Document Size
216 mm x 3048 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
AC 120/230 V (50 - 60 Hz)
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Microsoft Windows Server 2003 R2 (64-bit), Windows 10, Apple MacOS X 10.10.x, Apple MacOS X 10.11.x, Apple MacOS X 10.11, Apple MacOS X 10.12
29.7 cm x 15.2 cm x 15.4 cm
2.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Scan Element Type
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
26 ppm
Max Document Scan Speed Colour
26 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
26 ppm - black & white - A4 - 300 dpi , 26 ppm - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, Barcode Detection, blank page skipping, Text Enhancement, Auto Document Rotation, A3 stitching
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 3048 mm
Plain paper
Automatic
50 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
15 Watt
Power Consumption Stand by
4.1 Watt
Power Consumption Sleep
0.6 Watt
Software Included
EPSON Scan 2, EPSON Document Capture Pro 2.0
29.7 cm
15.2 cm
15.4 cm
2.5 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 80%
Interface: USB 2.0
Brand: Epson
Price Range Ex VAT: 300 - 500
